1990 906 Paso Thermostat
Posted: Thu Jun 21, 2007 2:25 pm
by CruisininVA
Hello,
I recently purchased a 1990 906 paso and the thermostat went bad along with the hose. I was wondering if anyone new where i could purchase one. Thanks.
Jerry
Posted: Thu Jun 21, 2007 7:27 pm
by persempre907
Where are you from?
Posted: Fri Jun 22, 2007 1:27 am
by CruisininVA
I'm in Virginia. But i will make arrangments if necessary. Where are you?
Posted: Fri Jun 22, 2007 12:40 pm
by persempre907
Rome, Italy.
So unfortunately, I can't give you any good advice to find it.
I hope some US member will help you soon.
Thermostat
Posted: Sat Jun 23, 2007 7:06 am
by marshman
Howzit
Parts all available ex your local Ducati dealer.Guy in NZ, Phil @
desmocycle@paradise.net.nz recently dismantled one.Try him!
Cheers Andrew
Posted: Mon Jun 25, 2007 10:28 am
by ducatipete
Its the same as fitted to 907 bike. My local UK Dealer, Pegasus has 907 parts on their computer but not 906. Don t think you can fit one from a newer bike as elbow connections are different. To check thermostat put into boiling water and see if it opens, ideally use a thermometer good luck
