different sprockets?
Posted: Thu Jul 12, 2007 2:16 am
Ok my other problem now is the rear sprocket. Then one I got from Bevel Haven is bigger in outside diameter and the inside diameter then the one that is on the bike. Totally different. A friend of mine gave me a pair of sprockets from his Paso that he used to own and they match up to the new one I got but not to the one on the bike. As far as I can tell it is the stock wheel.
So are there two different type of sprockets for the Paso? The hub would have to be different I would think since the bolt pattern is different.
I'm really perplexed here. Though the sprocket that came on the bike is from Sprocket Specialists and so is the replacement.
