Water pump leak
Posted: Thu Jul 26, 2007 7:36 pm
by steele
just discovered water coming from the little hole on timing cover :thumbdown: How easy is it to fix please :thumbup:
Posted: Thu Jul 26, 2007 7:53 pm
by persempre907
That is a very common issue of our bikes.
You have only to replace the ring on the shaft.
It's quite easy.
Good work.
Posted: Mon Jul 30, 2007 6:49 pm
by Finnpaso
Can U explane closer, from where that water is coming out? I fixed one time that "empting screw" thread from water pump cover with Helicoil system and it have been very good since. :thumbup: I have seen also some water pump covers for sale in ebay.
Posted: Mon Jul 30, 2007 7:32 pm
by steele
Its the seals leaking i have some on order from Baines racing. Should be easy enough to fix now i have looked at it properly :thumbup:
Posted: Wed Aug 01, 2007 6:34 pm
by persempre907
Yes, it will not to be a too much hard work!
