WANTED: (1) CDI for a 750 Paso (working condition)
mach5er
Post by mach5er »
BB1105 is the Kokusan part #. All I need is 1 unit.. Anybody have a spare??? Do I have other options ?
lockemj@houston.rr.com
http://www.electrexworld.co.uk/#3710X0
Not unusual on eBay.
As Ducatipart, still available but very expensive! :eek:
There is "fault" in these sites: They write, that those modules fit to 907, but 907 have NEVER used such things. Same with 906. :evil:
the 906 does not use CDI units ?! :umm:
Marelli "ECU", like later "usa Paso 750s" had. :evil: I havent ever seen other systems in 906s, ONLY Marelli systems. Btw, are ALL those Kokusan boxes samekind, or do some have different timing curves, etc? How about ordering numbers? Still: 907IE have P7 ECU(-91 modell), OR P8 ECU(most of -92 modells, maybe all?) :evil:
All the same.
DP have w other timing curves.
All the same, same no B 1105 IIRC.
paso144
year: 1986
Post by paso144 »
There are genuine Ducati Performance CDI boxes for sale. These are quite a bit cheaper about 150 euro each. You can still order them at Ducati.
greetz Remko
paso144
year: 1986
Post by paso144 »
There are genuine Ducati Performance CDI boxes for sale. These are quite a bit cheaper about 150 euro each. You can still order them at Ducati. They replace the original Kokusan units. You can also try E-bay.
greetz Remko
Solution:
Ignitech TCI-P4, go to igntitech.cz
Works as replacement for Kokusan boxes.
Have it on my Monster -97, wonderful!
Danish friend has it on a Paso 750, works great.
And cheap, this 118 Eu unit replaces both 300 Eu/ a piece boxes!
