Oil Level Sight Glass
Posted: Wed Sep 19, 2007 4:28 pm
One of the many things wrong with my Paso is that the sight glass for checking the oil level is cracked and leaking. I have set out to replace this part, but Ducati has discontinued it some time ago (part #066049183). According to the parts diagram, it is the same part as the ignition timing sight glass (also discontinued), but there is a difference between them. The oil level sight glass has a reflector, but the ignition timing glass does not.
I have set out to find a replacement, but am having difficulties in the great land of non-metric parts. I have been able to find a replacement with appropriate dimensions, but it is made of plastic and not good for temperatures above 160-degrees F (71-degrees C). I found another with all the correct dimensions and temperature rating, except for one dimension......it is an M33 x 1.5 thread instead of the necessary M35-1.5 thread.
Anyway, I just wanted to see if anyone out there may have some leads on a replacement sight glass.
These are the dimensions that I've gotten for the part...
paso750 (Gerhard) has pointed out that a person is selling some on eBay out of the Netherlands, but I'm a cheap bastard and don't want to spend $50 USD plus international shipping for the part (at least not yet). The ones that I have been finding that "almost" work are in the $6-$18 USD range, so I'll pursue this a little bit longer until I give up.
Here's the auction that Gerhard found earlier...
http://cgi.ebay.de/Ducati-Pantah-Sport- ... dZViewItem
