1989 750 sport 17" wheel conversion
Posted: Sun Oct 14, 2007 2:02 pm
by eliatt
Hi all,
Sport 750 has different rear fork than Paso. which bikes wheels can fit the best for a 17" conversion?
Has anyone preformed such a conversion for 750 sport and/or has a relevant link?
Thanks!
p.s.
Your inputs regarding carb conversion helpd me a lot. conversion will take affect soon, and I will publish data when finish. Thanks again!
Posted: Sun Oct 14, 2007 8:13 pm
... but it`s in german:
http://www.ducclub.de/technik/750s.htm
Posted: Mon Oct 15, 2007 7:34 pm
by eliatt
Thanks, G.
Posted: Wed Oct 17, 2007 5:38 am
by ducinthebay
The Sport is much easier to change to 17" than the Paso. The rear is as simple as getting an entire rear wheel from an SS or Monster. Brake caliper, hanger, wheel, sprocket carrier, etc. Keep the stock axle and slip it in. 4.5" wheels are generally much cheaper than the 5.5".
The front requires a bit more, as the brake mounts are your biggest problem. The second problem is the speedo drive. If you have access to a machine shop, you can download a CAD file on Bauke's site.
There is a bit on Bauke's page on converting, or on the http://sport-classic.net/ site, which has a topic for the Sport.
Posted: Wed Oct 17, 2007 10:08 am
by eliatt
Many thanks!
