Adjustable rear sets
Posted: Thu Oct 25, 2007 3:29 pm
by Stefano
Do you know if there is manufacturer of adjustable rear sets for Paso?
Thanks!!!
http://www.geocities.com/750paso/paso/italie.html :screwy:
Posted: Thu Oct 25, 2007 7:15 pm
by persempre907
Ciao Stefano,
there are many footpegs which fit on the Paso.
You can see on eBay and you have to search the footpegs which fit on the Paso (obviously), but also on the 90's SS, ST, 851/888.
For example
http://cgi.ebay.it/DUCATI-851-888-900SS ... dZViewItem
Posted: Thu Oct 25, 2007 7:28 pm
by Stefano
Grazie Francesco but
I'm looking for a manufacturer that makes adjustable rear sets.
Posted: Fri Oct 26, 2007 12:45 pm
by persempre907
Stefano,
I'm not sure you will able to find some adjustable rear set of footpegs.
Perhaps, you'll find (but it will be difficult) some front adjustable footpegs, but the rear ones...
The rear adjustable footpegs would also make raise and lower the mufflers...
No matter, good luck and let us know.
Posted: Fri Oct 26, 2007 12:57 pm
by Desmo_Demon
If I remember correctly from a few months ago, I checked the mount spacings of a rearset from a 748/916/996/998, and the mounting holes looked to be the same spacing. If this is the case, adjustable rearsets from any of those Superbikes would work. I'll try to remember and check the spacings, again, when I get home and post my findings here.
Posted: Sat Oct 27, 2007 12:25 am
by pompone
I bought a pair of pegs from LSL company in http://www.louis.de web page. :thumbup: :thumbup:
Posted: Sat Oct 27, 2007 9:50 pm
by Desmo_Demon
Desmo_Demon wrote:If I remember correctly from a few months ago, I checked the mount spacings of a rearset from a 748/916/996/998, and the mounting holes looked to be the same spacing.
I remembered correctly. Here I took a spare rearset from a 748/916/996 and mounted it to one of my spare Paso frames. It bolted directly to the frame with no modifications at all, so the 748-998 superbike rearsets will bolt right on to the Paso frame. You may have some issues with the shift lever and rear brake lever linkage and mounts, though....
Grazie
Posted: Sun Oct 28, 2007 7:09 pm
by Stefano
Thank you for all guys. :thumbup:
Posted: Mon Oct 29, 2007 1:33 pm
by Duc750
Clearance around the exhaust cans could well be an issue too - good luck
Posted: Mon Oct 29, 2007 2:39 pm
by Desmo_Demon
Duc750 wrote:Clearance around the exhaust cans could well be an issue too - good luck
+1....Good call. I forgot about that possibility!
Posted: Tue Oct 30, 2007 10:29 pm
by Duc750
One way round it would be to swap to a thumb brake - as I recall the real issue is with the rear brake linkage
