Rear Brembo pump
Posted: Mon Oct 29, 2007 9:19 pm
What is the name (code) of the rear brembo pump of Paso 750?
(PS 11 B)???????????
In regards to your inquiry, your bike should have the 20.2945.12 P108 caliper OE on the rear of the bike. The seal set you need is 120.2741.40.
You can purchase these from either of the following distributors:
TAW @ 303-456-5544
Yoyodyne @ 973-386-0040
Desmo_Demon wrote:I contacted Brembo a little over a month ago about the model of master cylinder and a rebuild kit for it. This is the response that I got (these are Brembo part numbers).....
TAW @ 303-456-5544
Sorry, but I do not know the difference. I bet the guys at Brembo can help. This is the guy who responded to my request for information on the Paso....Stefano wrote:Do you know the difference between the rear pump PS12 of Paso and the PS11B of 900ss from 91?
Gerhard Mr. know it allpaso750 wrote:the PS11B piston is by 1mm smaller than the one of the PS12. next to this obvious difference the B models have the exit for the brake line not on the lower end of the housing, but it`s on the side.
