Clutch hose routing.
Posted: Fri Nov 02, 2007 12:45 pm
by kirk332
I have overhauled the clutch pump and slave cylinder and bleed the system. All is working fine however I can't remember which way the hose was routed. Does the hose pass in front of or behind the head stem? I currently have it passing forward of the head stem however it appears that at full left lock the hose rubs more than I think it should. I feel that if I were to make it pass behind the head stem, then at full left lock it would have some fairly big bends on it however I could be wrong. I should have checked it out before bleeding or taken more notice prior to disassembly but!!!
Posted: Thu Nov 08, 2007 2:11 am
by kirk332
Problem sorted. It works out that I did take more notice during disassembly. I found a piece of paper lying around the floor of the garage which had explicit instructions on said hose, and how it was routed. Must have been one of those 3 am jobs!
Posted: Thu Nov 08, 2007 1:40 pm
by Desmo_Demon
kirk332 wrote:Problem sorted. It works out that I did take more notice during disassembly. I found a piece of paper lying around the floor of the garage which had explicit instructions on said hose, and how it was routed. Must have been one of those 3 am jobs!
So.....how is it supposed to be routed? I was going to tell you how mine was routed, but I have no idea if it is correct or not. The previous owner took the bike apart to powdercoat the frame, and, from what I can tell, didn't really know what he was doing when he put it back together. :laugh:
Posted: Fri Nov 09, 2007 12:47 pm
by kirk332
Mine was routed pretty much how I had it, that is as discribed above in my initial post. I could take a couple of pics if u need however I am away at work for the next two + weeks and would have to wait till then.
Cheers KB
Posted: Fri Nov 09, 2007 1:38 pm
by Desmo_Demon
kirk332 wrote:Mine was routed pretty much how I had it, that is as discribed above in my initial post. I could take a couple of pics if u need however I am away at work for the next two + weeks and would have to wait till then.
Cheers KB
So you had it routed correctly? :thumbup:
I'll have to doublecheck mine to see how it is routed. Some of the things on my bike are an absolute guess for me whether it is correct or not. :roll:
Posted: Sat Nov 10, 2007 3:04 am
by kirk332
Yes it was routed correctly, or should I say it is routed how it was before I took it apart!! :confused: ?
