1992 907ie with no service records
Posted: Wed Nov 14, 2007 3:08 am
by macwig
I recently bought a 92 907ie from a car dealer and they had no service records at all.Is there any online database to find out where and when service was done on this bike??
Posted: Wed Nov 14, 2007 10:27 pm
by paso750
no, unluckily there isn`t, specially as noone knows if the bike was serviced by an official Duc dealer or some other shop.
Best will be to find out the last owner and ask him otherwise start from zero, change all fluids, plugs, filters and the belts and check valve clearance.
Posted: Thu Nov 15, 2007 3:28 am
by Desmo_Demon
paso750 wrote:otherwise start from zero, change all fluids, plugs, filters and the belts and check valve clearance.
I would probably do all these things regardless what any previous owner tells me. It's better to be "safe" than to be broken down on the side of the road with a disabled Paso. :sad:
Posted: Thu Nov 15, 2007 6:16 am
by persempre907
Above all the timing belts.
They have to be changed every 20.000 km (16.000 miles).
If they go broken :ugh: :sad: :ugh: :sad: :ugh: :sad: .
service records
Posted: Thu Nov 15, 2007 7:45 am
by macwig
Thank you all and in the spring I will do full service as recommended.Mac
1992 907IE
1983 BMW R100
Posted: Thu Nov 15, 2007 1:39 pm
by Desmo_Demon
persempre907 wrote:Above all the timing belts.
I think it is 12k miles...or two years...whichever comes first.
(I typically go for 12k miles or up to four years, though)
Posted: Thu Nov 15, 2007 6:04 pm
by Rogero
BIG service every two years will keep things fine as long as you are not doing very high mileages.
Look after the battery though...
Re: 1992 907ie with no service records
Posted: Sun Dec 16, 2007 9:59 pm
by Ducman
LOCAL MECH ADVICE...FOUR YEARS MAX ON BELTS
