Page 1 of 2
steering damper exmple
Posted: Fri Nov 30, 2007 3:37 pm
by ducapiero
Hi guys i read on another section that you are interested in mounting a steering damper on our babies.....
i finish today to mount it ,don't lok on the rest of the bike it'so dirty
....cause i'm in the middl of various modification
P.s.
it's from a 999....
Re: steering damper exmple
Posted: Fri Nov 30, 2007 4:35 pm
I`m wondering, the mounting in the middle moves side to side or is it fix ?!
If I`m not thinking wrong and mounting is fix the damper will break sooner or later as the axle doesn`t move centered in and out.
Posted: Fri Nov 30, 2007 8:45 pm
by ducapiero
Gerard i don't understand so much of what are you saying....
why it have to brake???
i mount the damper very similar to aprilia tuono....
waiting for your answers
lamps
Piero
Posted: Fri Nov 30, 2007 9:00 pm
by Finnpaso
is it brake, broke, broken, etc....
Soon we have to have new section: "How to write and understand english well in Ducatipaso.org site....
Posted: Fri Nov 30, 2007 9:33 pm
by Fraser
Gerhard,
Have a closer look at the top photo. The damper is fixed by a substantial vertical bracket in 2 places, not just at the bottom. Should be good.
Fraser.
Posted: Fri Nov 30, 2007 10:26 pm
sorry, can`t find the right words to explain properly what I mean.
See this pic. At the mounting point of the damper and also at the end of the axle there`s a joint. The one at the housing will allow the damper to move when it`s mounted. It is mounted laying, not standing as shown.
Now imagine the damper mounted as it is shown (standing). Fix the damper in the middle so it cannot move and the end to the fork leg which will go back and forth. That will not work for long. The damper should be allowed to move when steering. On Piero`s bike it seems to be mounted fix.
Am I thinking wrong ?
PS: Antti, it`s break, broke broken and costs not coasts
Posted: Fri Nov 30, 2007 10:36 pm
by ducapiero
i have two joint in the mounting holes they are coverd by screw but they are there.....
i hope i understand....
lamps
Piero
Posted: Sat Dec 01, 2007 2:27 am
by jcslocum
Gerhard I'm pretty sure is referring to how the Pivot (Gelenk) is mounted to the frame. It looks like it will have to bend to make the full range of motion with the forks.
Posted: Sat Dec 01, 2007 5:33 am
by Laddie907
I know this is the 750 forum...but my 907 (with similar steering geometry) is nearly the heaviest steering I have come across - except the XS1100 yam.
do you find the 750 is "skittish"? or just looking for
I guess the damper will work OK and I can see the spherical mount in the Ohlins piccie that explains the pivot. The best test for the damper set up is if you get full travel on the stroke from lock to lock - if the damper stroke actuation is too short they are not fully effective.
Posted: Sat Dec 01, 2007 9:56 am
Thanks Jon. In one sentence that is exactly what I was trying to say.
If there was a pivot mounted to the frame allowing the damper to swivel there should be a vertical mounting bolt as there is at the pivot connection to the fork leg, but I can see only bolts that are horizontal (the one at the lower of the damper and the 2 at the frame).
Laddie907 you see it, where ? I don`t mean the pivot at the end, but the one at the housing.
Posted: Sat Dec 01, 2007 12:24 pm
by Finnpaso
You are 100% right, Gerhard, ill take for You
Posted: Sat Dec 01, 2007 1:09 pm
by Laddie907
there are 2 spherical bearings on the damper
there is one on the "right hand end" (eye at the rod end)
there is one at the bottom of the unit - on the lower part of the clamp
these - in combination - will permit a degree of flexibility (say 5 degrees each)
they must be correctly set up so the bearing can pivot in the radius area - if not the unit will bind - as you've described
it's one of those things you'd have to see and try to confirm the set up...
I guess the stroke is the most important issue to me.
Posted: Sat Dec 01, 2007 1:13 pm
by jcslocum
The end of the shaft has a "spherical" joint that will allow some movement. The "body" also has a shperical joint at the pivot point to allow for some movement. I wonder if it is enough for a full range of motion. Ducapiero, can you take a picture of the damper with the steering turned full left and full right?
The body of the damper is usuall (normally) mounted so that the pivot joint is in the horizontal plane with the bolt coming from the top. Like this:
Posted: Sat Dec 01, 2007 1:23 pm
If the damper would be mounted as in your pic Jon, I`d say its fine, but mounting the damper standing instead of laying limits the movement to the possible swivel of the joint and that I don`t think is enough for full steer, but as Laddie907 said one should really be there and try.
Piero many thanks to post the pictures, I would have never thought to mount it there. I may copy that
Posted: Mon Dec 03, 2007 1:31 pm
by ducapiero
