Clutch help needed
Posted: Wed Dec 26, 2007 9:02 am
Hi all,
Can anyone supply me with the measuraments of the mushroom-like part located on the clutch slave cylider? the stem goes in the bearing, and is 8 mm. diameter, the rest - I don`t kow of. I guess that the "mushroom" head should be approx 15 mm. diameter, since it`s in contact with the pressure plate that has approx. same contact area.
I`ll appreciate your help!
Thanks in advance,
Eli
Thanks in advance,
Eli
