Rear rotor from the 16” wheel fit the 17” wheel?
Posted: Fri Feb 01, 2008 5:16 pm
by nilaus
Hi
I have just bought me a set of 17" front and rear from a 600 SS on ebay, all thou with out the front rotors, which I will be looking out for, so I am a bit exited to getting started with the conversion :P .
My question is, does the rear rotor from the 16” wheel fit the 17” wheel?
Regards, Klaus
Denmark
PASO 750 , 1990.
Re: Rear rotor from the 16” wheel fit the 17” wheel?
Posted: Fri Feb 01, 2008 8:29 pm
by ducapaso
I don'think so.
I haven't o.e.m. ducati rims, but i think that the fitting will require a machined spacer anyway :?
Posted: Fri Feb 01, 2008 11:46 pm
by zap
:D yes that is true!
I've got a 17" backwheel with the original paso rotor, but you have to mount a spacerring between wheel and rotor.
I will measure it and get back to you again.
:thumbup: ab.
Posted: Tue Feb 12, 2008 9:06 pm
by zap
:thumbup: hi,
of course, i forgot to reply but i just measured the spacerring.
first i've got to say that i've mounted the original brake disc from a paso 750 to a 750ss rear wheel (same as 600ss 17x4.5).
the ring between those two parts is 13mm. wide.
also check the rear bearring problem :banghead: my wheel had to be honed 1 mm around (2 mm. in diameter) to make the original paso rear axle fit.
:beer: good luck!
ab.
Posted: Tue Feb 12, 2008 9:37 pm
by nilaus
Regarding the back wheel,. I am puzzled that know one has mentioned the bearin problem before :? , but this is just an issue which must be delt with. Did you make a new inner spacer for the back wheel or could you reuse the one from the 16” wheel ( I mean the hollow shaft between the bearings). My new 17” front wheel has a 47 x 20 x?? bearing. but this can just be changed to a 47 x 17 x ?? bearing, so no problem. I am hoping to make list and also take pictures of the conversion on “how to do” or maybe “not to do” ;-) and what needed.
Regards Klaus.
Posted: Thu Feb 14, 2008 11:21 pm
by zap
hi klaus,
i think the inner spacer can be reused, but i do not know for sure( someone did it for me).
about the bearrings, i have to measure it again.
i only know that i've got to take 1mm around from the bearring hole to make the right bearring fit.
:beer: good luck!
ab.
