Headlight mod ST2, good f Paso?
Posted: Mon Feb 11, 2008 5:29 pm
From another Forum:
Is this mod something we could copy to our Paso`s?
I did not exactly understand what he did, can anyone explain?
Reply:I heard all of the complaints about the ST headlight and how the only fix was the $550 Ducati Designs headlight. But, I wasn't going to dump that much money into the ST. So, I tried upgrading the bulb to an HID. It helped but I was still disappointed with the light output and beam pattern. So, after successfully modifying my 1098 headlights by removing the metal cutoff inside, I decided to give it a try on the ST and the results were even more dramatic. The beam pattern and light output are so much better. So save yourself $550 by removing a single philips head screw.
Reply from author:may well be, but that shield is there to prevent direct light from being radiated from the filament. a cop may think you always have your high beam on, and oncoming drivers will see a lot of glare. be careful.
I've done it before, with the same results as you, so this is just a heads-up.
I hear you. But, if you put the DD light on you get the same effect. You can just lower it to keep the beam from going to high.
