Page 1 of 2
K&N filter
Posted: Thu Feb 21, 2008 7:59 pm
by persempre907
What kind of K&N filter will fit on the 907IE?
I tried to search on the forum but I wasn't able to find anything.
I bought the DU 0900, which fits on the 750, but also on the 851/888/900SS etc, but I found out it is higher than the stock kind, and I guess it doesn't fit well into the airbox.
Can someone tell me something more about?
Re: K&N filter
Posted: Thu Feb 21, 2008 8:49 pm
by persempre907
Re: K&N filter
Posted: Thu Feb 21, 2008 10:38 pm
by ducbertus
Francesco,
I fitted one in mine as well. the fit was more difficult as the orginal filter. It seemed to me that the foam sides of the filter are thicker, because the latches were more difficult to close. A firm push did the job.
I still have box of K&N filter. I'll look for you and let you know what is says.
Ducbertus
Re: K&N filter
Posted: Fri Feb 22, 2008 12:50 am
by Tamburinifan
Same spare part no f all 90`s 2V Ducs.
The higher one is "race", but fits.
Have you tried it?
Re: K&N filter
Posted: Fri Feb 22, 2008 10:41 am
by persempre907
Tamburinifan wrote:Have you tried it?
I have tried to fit it in my spare airbox, but I haven't pressed too much the lid to avoid damaging it. If it doesn't fit, I would get back it to the seller.
Tamburinifan wrote:The higher one is "race", but fits.
Has it to fit without any modification to the airbox lid?
Re: K&N filter
Posted: Sun Mar 02, 2008 11:51 am
by Finnpaso
Both, normal and "race"(higher)would fit without any problem to normal Paso airbox... at least mine fitted, cause i have both.... Now i use that normal in my 907 and that "race" version in that bike, what i use "dayly", like its now in my ST2. I cant remember number codes just now....
Re: K&N filter
Posted: Mon Mar 03, 2008 4:18 pm
by persempre907
Do you think I'll need to adjust the carburation when I'll fit that filter?
Re: K&N filter
Posted: Mon Mar 03, 2008 9:53 pm
...and that "race" version in that bike, what i use "dayly", like its now in my ST2. I cant remember number codes just now....
http://www.knfilters.com/search/product ... od=33-2003
The DU-0900 won`t require carburation changes.
G:
Re: K&N filter
Posted: Tue Mar 04, 2008 12:34 pm
by Finnpaso
As he say, no need richer chip, but if change to more open exhaust, then need to adjust mixture(new chip).
Re: K&N filter
Posted: Tue Mar 04, 2008 11:39 pm
by persempre907
Re: K&N filter
Posted: Wed Mar 05, 2008 12:28 am
by Tamburinifan
Just tried the high "race" filter in my 907 airbox. Fits mine w/o problems, including lid.
Re: K&N filter
Posted: Wed Mar 05, 2008 2:48 pm
I'm amazing: in that web page there is the "vehicle applications" of that filter.
It seems that filter fits only on some cars and not on the bikes.
I found that in my P750 when I bought it. Specs are similar.
33-2003 Product Specifications
Product Style: Panel Air Filter
Height: 1.563 in (40 mm)
Outside Length: 8.25 in (210 mm)
Outside Width: 8.125 in (206 mm)
DU-0900 Product Specifications (DU-0900 replaced the old 33-2566)
Height: 0.75 in (19 mm)
Outside Length: 8.5 in (216 mm)
Outside Width: 8.375 in (213 mm)
there`s also a DU-9098
DU-9098 Product Specifications
Height: 1.188 in (30 mm)
Outside Width: 8.25 in (210 mm)
http://www.knfilters.com/search/applica ... od=DU-9098
Re: K&N filter
Posted: Thu Mar 06, 2008 12:48 am
by Debonair
The airbox on my 750 has a section cut-out on it! I have #754693, can anybody tell me if this necessary or should I cover this cut-out back up (it has a K&N filter).
Re: K&N filter
Posted: Thu Mar 06, 2008 7:38 am
by persempre907
It seems that the fitting of that filter in some airbox requires a modification to the lid.
Specially, on the 851/888 and on the SS series, that filter fits only cutting the lid.
I think that when the lid is cut out the engine should better "breathe".
Re: K&N filter
Posted: Thu Mar 06, 2008 9:14 am
guys be careful. This is the 907ie forum and Debonair has a 750.
The airboxes are totally different. May ge a good thing to cut the airbox lid on a 907ie, but I wouldn`t do this on a 750.
