Pazzo levers
Posted: Sat Feb 23, 2008 5:19 am
by Cybermunster
I'm trying to get a set of adjustable Pazzo levers that will fit my '92 907, will the ones for a 900SS or 916 work.
The seller does not have them specific for the 907 so wondering if I can use from other models.
Thank you.
Re: Pazzo levers
Posted: Sat Feb 23, 2008 9:44 am
by persempre907
If you have the stock master cylinders on your 907, the 916 levers will not fit.
You have to choose the early SS (until 1997) and Monster (until 2003) ones.
They have the shape below, and fit both for the brake and the clutch master cylinders,
while the 916 ones have the shape below.
Later, the fitment will be very easy.
Re: Pazzo levers
Posted: Sun Feb 24, 2008 4:53 am
by Cybermunster
As usual sir, you are correct, tried a set from my brother's '91 900 SS and they fit perfectly (same exact levers).
wooo hooo ..I'm ordering my Pazzo adjustables!!
Many thanks!!
Re: Pazzo levers
Posted: Sun Feb 24, 2008 5:05 pm
by jcslocum
The Pazzo's are nice and the price is right! I have them on my 900SS.
Re: Pazzo levers
Posted: Fri Feb 29, 2008 2:40 am
by Shelboss
What about short vs. long Pazzo levers, any preferences?
Re: Pazzo levers
Posted: Fri Feb 29, 2008 2:45 am
by Cybermunster
My brother has the "shorties" on his 900SS, the brake is good but the clutch is a bit uncomfortable (too short for full 4 finger pulls).
Re: Pazzo levers
Posted: Wed Mar 05, 2008 10:51 pm
by jcslocum
I have the shorty levers. Seems to work fine for me.
Re: Pazzo levers
Posted: Thu Mar 06, 2008 1:29 am
by Cybermunster
Just installed them ...piece of cake! ..they look great and now I can adjust and compensate the clutch friction zone.
Only thing I would do different would be to use a "shortie" lever for the brake and a "long" lever for the clutch, they do come in combined length sets.
Re: Pazzo levers
Posted: Thu Mar 06, 2008 9:03 am
by Finnpaso
Any link to "Pazzo" levers ?
Re: Pazzo levers
Posted: Thu Mar 06, 2008 5:05 pm
by jcslocum
GGGGGGoogle says:
http://www.pazzoracing.com/
No Google in Finland?
Re: Pazzo levers
Posted: Fri Mar 07, 2008 7:40 am
by persempre907
Re: Pazzo levers
Posted: Fri Mar 07, 2008 7:11 pm
by Finnpaso
Frankie, this time Your are "little wrong": I start to be "too LAZY" to search all things by "kuukkeli", as we call Google.... and we surely have plenty of new very hig tecnology here, like very fast internet connection in near every house
Surely we have Google...
As You know, companies, like Nokia is coming from Finland, no matter they make them already in hole world... also in china
Minä kyllä ymmärrän, että yritätte "vittuilla" minulle silloin tällöin, mutta "paskat siitä" !!!!
btw, do You guys let me to "pensioner", when i reach 2000 mails/advices to these sites ?????
...that i can concentrate ONLY for DRIVING my Ducatis!
Re: Pazzo levers
Posted: Sat Mar 08, 2008 1:49 am
by Desmo_Demon
I did some checking, and the levers should be the same between the Paso 750 and the 907, and......I also know that the levers from the '97-'00 ST2/ST4 (maybe up to '02) will fit the stock master cylinders, also. Here is a picture of the lever from a '98 ST2 (silver) on the master cylinder of a 1988 Paso 750.
Here is a picture of the two levers side-by-side...
I know the '00 ST2/4 levers are the same as the '98, as I upgraded my master cylinders in '00 on my ST2, and the levers are interchangeable. I believe the ST bikes used the same levers until at least '02, but someone may want to check on that.
Re: Pazzo levers
Posted: Mon Mar 10, 2008 3:44 pm
by Cybermunster
