Swingarm bearings code
Posted: Wed Feb 27, 2008 12:11 am
by ducapiero
hi guys before mounting all rear parts i thinked to change bearings of the rear wheel and of the swingarm....
but i'm not able to read the code of this :oops: :oops: :oops:
waiting for your answers.....
lamps
Piero
Re: Swingarm bearings code
Posted: Wed Feb 27, 2008 9:56 am
by paso750
Posted: Wed Feb 27, 2008 9:35 pm
by ducapiero
Thanks Gerhard but i'm not able to read the codes,in the post that you linked.....
i don't understand sealing bearings....i'm so confused cause my english i too school version :oops: :oops: :oops: :shock:
can you tell me the codes?
thanks
Piero
Posted: Thu Feb 28, 2008 6:40 am
by ducapaso
just give me the measures, I'll search in the f.a.g. catalogue! :thumbup:
Posted: Thu Feb 28, 2008 11:10 am
by paso750
Ciao Piero,
i 2 cuscinetti della ruota posteriore (uguale come nella ruota anteriore) sono: SKF #63004-2RS1 C3 (20mm diametro interno x 42 diam esterno x 16mm larghezza) . Sono i stessi cuscinetti che si trovano nella forcella posteriore sulla destra (2x).
http://www.consbrgs.com/page.taf?detail=54_1_5 ("Interchange" sono i tipi alternativi)
i 2 cuscinetti sulla sinistra della forcella posteriore sono HK 2520 INA WX (diam. interno 25mm x diam esterno 32mm x larghezza 20mm)
http://www.consbrgs.com/page.taf?detail=196_1_39
L`annelli di tenuta (2x) sono INA 62 G 25-32-4 o Cortego A13 CFW B1OF 25-32-4 (le misure sono: 25mm diam. int-32mm diam.est- 4mm larghezza). Le trovi senza problemi da Ducati. (B1 significa che il annello e in metallo con la fascia elastica di tenuta in gomma e OF significa che e un annello senza molla). Sembra che HONDA li usa per esempio sulla 2001-2003 Honda CR250 o 1997 CR500.
Per battere fuori i cuscinetti ho usato un "wrench nut" (cos`รจ la parola italiana ?!) da 24 e 30mm.
Gherard :)
I don`t translate all this in english as it`s basically the same as in the links above.
PS: this seems to be an excellent site to look up bearings as it lists the types of numerous manufacturers (unluckily there`s no search function so you have to click "forward" until you find what you`re looking for): http://www.consbrgs.com/html/catalog3.html
Posted: Thu Feb 28, 2008 11:50 am
by ducapiero
Gherard thank you very very much!!!!! :) :) :) :) :) :)
