Page 1 of 2
New Ducati owner 88 limited
Posted: Wed Feb 27, 2008 4:04 am
by Johnnie
I recently bought the 88 limited that was for sale on ebay in Glendale AZ, I did as much research as I could and feel confident its a real one. I wanted a red one but couldnt pass up the limited for obvious reasons.I'm going thru it now most of the items that need attention are relativley easy fixes (brake light switches, front tire, breather tube and breather filter, turn signal lens. Unfortunatley the previous owner replaced the large original mufflers with standard paso units, I guess the original ones were kinda rough and he ended up throwing them away. does anyone know if the big muffs show up for sale occasionally??? the only other non stock item is the 906 mikunis that were installed which I would have done anyway. this is my first duc, I always lusted after the pasos and I cant believe I didnt take the opportunity to ride one back in the 80s, I wasted all these years riding my kawasakis when I could have had one of these. It's never to late to change!!! John
Re: New Ducati owner 88 limited
Posted: Wed Feb 27, 2008 9:40 am
by paso750
John, welcome. Like every new Paso owner you should check the service history of the bike. In case you don`t have that info check valve clearance and replace the belts also.
The Mikunis come from a Supersport or Monster as the 906 had the same Weber carb as the P750.
The race cans that came with the Limiteds are for race use only. I`d say also on ebay they are hard to find.
Posted: Wed Feb 27, 2008 1:35 pm
by Desmo_Demon
Johnnie wrote:does anyone know if the big muffs show up for sale occasionally???
I'll check and see what I may have laying around. As I stated in the classifieds thread that you responded to, I have four sets of slip-ons that I plan on inventorying and determining which (if not all) that I want to get rid of. I have two sets of OEM slip-ons, but I think both sets are identical. I'll try to check in the next few days.
Oh yeah.....welcome to the forum!!!
Posted: Sun Mar 02, 2008 7:06 am
by Debonair
What's up guys? I just bought my first Ducati today! It's an 88 750 paso and it came with F1s pipes. It does not run at this time. I think it's got oil in the starter, theres power going to it but it doesn't turn. I will get it going soon....
Posted: Sun Mar 02, 2008 10:51 am
by paso750
check the brushes of your starter, they might be worn.
Posted: Mon Mar 03, 2008 4:44 am
by Debonair
I'm looking to re-do it all brushes, commutator and seals if I can find them! I'm really excited because I have never riden a Ducati, I have a 92 GSX-1100g and an 82 Yamaha Vision so I really want to hurry up and get the Paso going. I will keep all of you posted on my improvement.....
Posted: Mon Mar 03, 2008 4:39 pm
by persempre907
Drive carefully your Paso the first times, and above all, take care in the corners... Never brake in it!
Posted: Tue Mar 04, 2008 2:27 am
by Debonair
Thanks, I'll try to remember that! Can you tell me what kind of engine oil you recommend and how much to use.
Posted: Wed Mar 05, 2008 1:22 pm
by jcslocum
I've never seen oil in the starter. Do you see oil coming from it??
Gerhard is right, check the brushes. This can be done with the starter mounted to the engine and is relatively easy to do. There are also electric/wiring issues with the Paso that seriuosly effect starting so please read thru the FAQ at the top of the forum. We have tried to compile every problem you might encounter!
Replace the belts before riding if you don't know their age and just use a good 10-40W or 20-50W motorcycle oil. My Paso liked regular motor oil vs. synthetic.
Posted: Wed Mar 05, 2008 1:40 pm
by Desmo_Demon
jcslocum wrote:I've never seen oil in the starter. Do you see oil coming from it??
I've never run across oil in the starter, either, but......there has been at least one thread on the
http://www.ducati.ms forums about oil in the starter of a 996 (I think it was a 996). Appearantly it is not too uncommon, as a couple other people said they had the same issue. Appearantly, there is an o-ring or seal around the shaft of the starter which can fail and allows oil to get into the starter from the crankcase. In the situation listed on the ducati.ms forum, the guy had starting issues and literally had oil dripping out of his starter....if I remember correctly.
Edit - I was wrong...it was on Speedzilla. Here's the thread....
http://www.speedzilla.com/forums/genera ... motor.html
Posted: Thu Mar 06, 2008 12:30 am
by Debonair
Can you guys tell me where I can acquire the belts,starter brushes etc. here in the states. I'm sure to find a place but since you are veterans here ,maybe you can guide me...
Posted: Thu Mar 06, 2008 9:21 am
by paso750
some parts, like belts or turn signal covers you should be able to order and get via your Duc dealer. Have you tried the search function of the forum for the starter brushes ? This was discussed a few times already.
Posted: Thu Mar 06, 2008 5:03 pm
by jcslocum
This is the only place to call in the USA:
Miles English
Parts Manager
BCM Motorsports
603-524-4898
http://www.bcmducati.com
Miles will take care of you. Make sure to tell him Jon Slocum sent you.
Posted: Fri Mar 07, 2008 2:26 am
by Debonair
Will do Jon, thanks for the info!
Posted: Fri Mar 07, 2008 7:02 pm
by Finnpaso
jcslocum wrote: use a good 10-40W or 20-50W motorcycle oil. My Paso liked regular motor oil vs. synthetic.
I would say; 20W-50 would be much better to ALL Ducati engines, that "too thin"(when engine is hot)10W-40...
I give "advice": Shell FULLY synthetic ADVANCE ULTRA 4 15W-50....
