So, a 180-60-16 will fit a paso swingarm without modification you believe?
This company did the conversions:
Moto Helmut Thome
Wersch 37
53804 Much
Germany
There was a Paso being sold on ebay Germany like 2 or 3 years ago and I contacted the seller. He pointed me to the company. I contacted them and they willingly gave me more info. They did use a 520 chain, spacers for the sprockets and they also lenghtened the center stand (not sure if that is really necessary). Of course the excenters would have to be rotated a bit back so you`ll lose some of the chain adjustment range.
I`ll only be able to confim this to you personally by mid of next months when I have the tire.
The tire height seems to be a bigger problem than its width.
Checking the Avon website for measurements:
AV72 180/60-16: diameter 630mm, width 182mm (measured on a MT5.00 rim), recommended rim: 5.00-5.50
AV46 150/80-16: diameter 644mm, width 152mm (measured on a MT3.50 rim), recommended rim: 3.50-4.25
AV60 170/60-17: diameter 636mm, width 172mm (only mentioning this as there are guys using this size on a P750)
Unluckily I couldn`t find any corresponding info on the M59X in 160/60 or 160/70-16 (which I also saw on a Paso once).
However, if a 17" wheel fits without touching the front of the swingarm the 180/60 will too. Both are lower than a 150/80.
If you remove the excenters draw a line from each excenter`s hole middle and then measure from the lines center to the front of the swingarm you`ll get ca 320mm. So clearance to the front is small but there is one and if you rotate the excenters back as the company told me it can be slightly increased.
The swingarm width (measured at the weldings of the center section) is 198mm. Theoretically on the sides one should have 5-7mm clearance from tire to the swingarm. All in all I`m pretty confident it`ll fit.
Gerhard
PS: since 2004 in Germany tires with a lower speed index (i.e. HR max. 210km/h instead of ZR > 240km/h) can be homologated as long as the index is higher than the topspeed stated in the vehicle`s documents The rule for 4 wheeled vehicles is: topspeed + 6,5km/h + 0,01 x topspeed. The TÜV seems to use the same rule also for bikes. I guess within the EU there are similar rules.
According to tire infos I found a tire will heavily lose load capacity at speeds excessing its speed index which is the greatest issue. So the higher load index of the AV72s will do no harm and the downside of needing more time to get to temperature may be equalized by lowering tire pressure slightly. Probably to early to talk about this, let`s try it first
