Clutch Woes
Posted: Tue May 13, 2008 7:05 am
5/13/08
Opps. Posted this on the Paso list by mistake.
I have a '90 750 Sport. I gather that all 5 speed clutch packs from this era are the same.
Could someone give me order and orientation of assembly for plates?
I have a parts manual PDF that shows an order....but It looks like there are two different steel plates....and I believe one if not both are convex?
I had a slipping clutch....I installed the new clutch pack in the correct order (I thought...though I had no instructions...and the shop manual stinks).
Now the clutch "grabs"..and chatters.
Any ideas? Air in the line?
Is there a "spec" for stack height? How is it measured?
If stack height is to high...how do you vary?
Thanks a MILLION.
Jeff
Thanks a MILLION.
Jeff
