Page 1 of 2
speedo drive
Posted: Fri May 16, 2008 6:24 pm
According to my dealer this is probably one of the next parts that will become rare.
Putting the front end back together again today I noticed the first time that the speedo drive has a grease nipple. So every couple of years one should give it some grease if it doesn`t turn freely like mine did.
The internal parts are probably plastic so it`s better not to use oil. (just a guess, could be brass or some other material also)
Re: speedo drive
Posted: Sun May 18, 2008 8:30 am
by ducapaso
Re: speedo drive
Posted: Sun May 18, 2008 9:55 am
ratio is 21/12
Why are you unable to replace it ? Ducati still has it and Stein-Dinse is selling it for around €40,-.
This one looks like it but it doesn`t mention axle diameter, width or ratio:
http://cgi.ebay.de/aprilia-rs-tachoantr ... dZViewItem
Re: speedo drive
Posted: Sun May 18, 2008 11:49 am
by Finnpaso
Can that part find from Aprilia (125cc) spare part catalogues? Just quessing now.......
Re: speedo drive
Posted: Sun May 18, 2008 12:42 pm
according to the auction:
aprilia
RS 125 1996-2005
RS 250 1995-1997
Re: speedo drive
Posted: Sun May 18, 2008 1:08 pm
by Finnpaso
Ok, thanks!
Re: speedo drive
Posted: Mon May 19, 2008 2:08 pm
a seller on ebay told me width is 15mm, ratio is not mentined on the part and axle diameter is 20mm.
The Paso axle is 17mm.
Re: speedo drive
Posted: Mon May 19, 2008 2:35 pm
by Finnpaso
then have to make spacer to fit it to Paso.... What is wheel size in Aprilia? That can lead to ratio, but i think, its NOT 16", as in Paso
Re: speedo drive
Posted: Mon May 19, 2008 3:46 pm
yes, 17"
Re: speedo drive
Posted: Mon May 19, 2008 4:09 pm
by Finnpaso
So right ratio for 907IE...... But propably again problems with axle diameter... Anyway, spacer is not so difficult to do with lathe.
Re: speedo drive
Posted: Tue May 20, 2008 5:44 am
by ducapaso
paso750 wrote:a seller on ebay told me width is 15mm, ratio is not mentined on the part and axle diameter is 20mm.
No matter! the inner spacer inside the speedo can be disassembled and switched to the other! All the speedos of this kind suppurt such job!
Re: speedo drive
Posted: Tue May 20, 2008 4:48 pm
have you done it before ? However, that only makes sense if your original housing is broken, not if something inside is defect.
I was discussing with Antti before, what washers/spacers are on the left and right side of the front wheel ? I found only one. According to the parts catalogue there`s one that comes with the speedometer drive. How does that one look like? Anyone have pictures, what are the measurements ?
Re: speedo drive
Posted: Tue May 20, 2008 5:00 pm
by ducapaso
paso750 wrote:have you done it before ? However, that only makes sense if your original housing is broken, not if something inside is defect.
When I disaswsembled mine, I tried to install another one, with different inner diameter, but it was an unclocwise spinning!
Re: speedo drive
Posted: Thu Jun 05, 2008 10:23 am
by Desmo_Demon
Lat week, I just had the tab that fits into the front wheel break on my Paso. I had a spare speedometer drive unit, so I installed that one. Does anyone know if I can buy just the back plate with that tab? That piece is easily removable with a simple retaining ring that you can pull out of the unit with your fingers.
Re: speedo drive
Posted: Mon Jun 09, 2008 7:15 pm
by cagiva905
I had a similar problem on the speedo drive of my 350 Elefant a few years back (similar drive). I was able to weld the notch back on the ring, and thoroughly cleaned and greased the inner parts. I was not able to disassemble it completeley but the ring came off. I put everyting back together but also, to prevent twisting of the ring, I put some strips of neoprane tape on the ring that now is pushed flush with the gear by the wheel hub. No problems so far
Michiel
http://www.elefant.nl
http://www.endless-horizons.net
