front wheel spacer issue
Posted: Wed May 21, 2008 6:20 pm
by paso750
as I wrote in another thread I have a problem assembling the front end of my bike.
According to the parts catalogue there are 2 spacers at the front wheel. One on the right side and one at the speedometer drive.
What outer diameter and exact width are these ?
If anyone has the front wheel removed, could you check ?
thx,
Re: front wheel spacer issue
Posted: Thu May 22, 2008 1:36 am
by Desmo_Demon
Here are the measurements I got with a metric ruler...
17.5mm ID x 26mm OD x 2mm
with a micrometer, I got this...
0.678" ID x 1.012" OD x 0.077" thickness
Both of my bikes only have one spacer on the right side. Neither has one on the speedo side.
Posted: Thu May 22, 2008 8:52 am
by paso750
thanks very much. Strange that the manual shows one per side.
I saw an old 851 yesterday and that one had a spacer per side also.
I still wonder why there is a spacer on the right side as they only had to make the axle some milimeters longer. Only guess I have is that the threaded part shouldn`t stick out on the left fork side.
Posted: Thu May 22, 2008 5:32 pm
by paso750
Terry,
did you actually remove the axle to check ? Just wondering if the "spacer" on the speedometer drive side could be a shim which is hard to see with the wheel still in place.
Posted: Fri May 23, 2008 10:02 am
by Desmo_Demon
paso750 wrote:did you actually remove the axle to check ? Just wondering if the "spacer" on the speedometer drive side could be a shim which is hard to see with the wheel still in place.
Johnnie asked me the same question aboput washer dimensions a couple of months ago and I still had the response from when I PMed the info to him. I used a caliper on the washer. If there is supposed to be a spacer on the speedo drive side, neither of my bikes had them.......By any chance is that "spacer" in the schematic actually a bushing for the speedo drive unit to take the ID from 20mm to 17mm? I broke the tab on my speedo drive unit on the way home from work two days ago and I was cleaning up a spare that I have and saw a bushing as a reducer for the ID. Chances are, I will be removing the front wheel this weekend to change the drive unit and can double-check everything.
