Anyone Have Their Paso's Engine Removed?
Posted: Sat Jun 21, 2008 10:39 pm
by Desmo_Demon
I think Gerhard stated that he has his engine out of his bike, but just in case he doesn't...
I need the measurements of the Pantah engine at the lower mounting points of the engine. They are very difficult to get an accurate measurement with the engine in the bike. Here are the two points I need....
It looks like there is a spacer on the right side (brake side), but if I can get the measurements of each side from the joining point of the engine cases, I can determine how wide the spacer needs to be later.
Thanks!
Re: Anyone Have Their Paso's Engine Removed?
Posted: Sun Jun 22, 2008 7:32 am
by ducapaso
You can ask to lcerani as he switched a SS900 engine in the paso frame, so he had to machine all the "difference"s between newer and older carters!
Posted: Sun Jun 22, 2008 10:21 am
Hi Terry,
it`s already a few months now that my engine is back in the frame, Pitty, I could have measured before.
Posted: Sun Jun 22, 2008 3:06 pm
by Desmo_Demon
paso750 wrote:it`s already a few months now that my engine is back in the frame, Pitty, I could have measured before.
I may have to find a way to raise the bike high enough for me to crawl under it. That bottom engine mounting bolt has an open area in the center section, so I really need to be directly under it to make sure I am not skewing the reading any.
Posted: Sun Jun 22, 2008 6:42 pm
by jcslocum
I have an engine out of frame but need a new battery for my calipers!!! Can you wait until next weekend?? I travel again this week for work....
Posted: Sun Jun 22, 2008 8:42 pm
by Desmo_Demon
jcslocum wrote:I have an engine out of frame but need a new battery for my calipers!!! Can you wait until next weekend??
:lol: I was wondering why you need batteries for your brake calipers and how that would affect being able to get measurements! :D :banghead:
I've just been using a small, steel ruler measured in 64th of an inch to get the measurements that I have been using. The frame will flex a little when I tighten the engine bolts, so I'm sure being 1/64" - 1/32" off shouldn't be an issue.
I can wait until next weekend if necessary. I'm not in any huge hurry. :lol:
Posted: Mon Jun 23, 2008 2:29 pm
by Desmo_Demon
I'm getting closer to being able to install this engine. I tried to fit it into the frame, last night, and I'm still a fraction of an inch off on those bottom two mounting tabs. The Pantah engine has a spacer on the rearmost two mounting points, and I'm trying to let the engine cases stay wide enough to not need spacers, but this is makign it very difficult to try to install. I'm going to do some more trimming and shaping, and if I can't make it go in easier, I may have to trim more on the right sides of the cases and use spacers to make installation a bit easier.....I'm getting closer. I'm hoping this works.
Posted: Tue Jun 24, 2008 4:34 am
by ducapaso
ducapaso wrote:You can ask to lcerani as he switched a SS900 engine in the paso frame, so he had to machine all the "difference"s between newer and older carters!
I can remember there're other small diferences to machine...
Posted: Wed Jun 25, 2008 10:00 am
by Desmo_Demon
I got the measurements and am getting closer to stuffing this engine in the frame.
The ST4 engine has different heads on it, as the cams sit lower in them and they are shorter than regular desmoquattro heads. I noticed last night during some trial engine mounting attempts that the horizontal head's belt cover my hit the frame rail.
I'm taking this in baby steps to make sure I don't destroy anything. I hope this works. Wish me luck!
Posted: Thu Jun 26, 2008 11:04 am
by Desmo_Demon
Well, I now understand why engine swaps are not common occurances with the Paso bikes. I'm still working on this engine installation, but it is not as easy as I was hoping.....but still not as difficult as it could be. Here's an update to the Mega Paso Project. I'll add this link to the Mega Paso thread, also.
http://www.desmodemon.com/mega_paso/engine.html
