fuel economy 907 1991 PLEASE HELP ME!!!!!
Posted: Tue Mar 29, 2005 2:40 am
by DUCATENO
hi, my 907 its like a 8 cilinders fuel economy....... it is giving me just 3.5 miles per liter....... do anybody knows what can the problem be? forgive my english i´m from mexico..... here is very dificult to found somebody capable to fix my duc...... 2 weeks ago i changed filters, oil, "bujias", check conections but still the bad economy......PLEASE HELP ME!!!!!
Posted: Tue Mar 29, 2005 5:15 am
by Skins
Eugenio, is is possible you have a fuel leak somewhere? It could be anywhere, and leaks only from vibration when the bike is running on the road, and the fuel evaporates, so you don't see the wetness. There may be a crack in a weld of the fuel tank, which leaks only with vibration, and the fuel evaporates from the heat of the motor. I had that once, many years ago, before the Paso.
Posted: Tue Mar 29, 2005 5:47 am
by redpaso
I reckon you must be right Skins, I can't think of anything else that would churn the juice that fast on a Paso. I hope it is a leak because if the engine is using that much it can't be good.
Posted: Mon Apr 18, 2005 1:30 pm
by cagiva905
If the fuel consumption suddenly has risen, than I suggest you check the water temp sensor of the fuel injection. If this failes, the ECU will think it is much colder (even below zero) and richen the mixture, resulting in bad running and excessive fuel consumption.
You can find datasheets of the sensors on
http://www.endless-horizons.net/efi/efi.htm
Michiel
(Elefant 900ie owner and former Paso 750)
Posted: Mon Apr 18, 2005 7:47 pm
by Skins
He did find a leak in the tank, fellas, so that was at least part of the problem. I haven't had any further news at this time.
Re: fuel economy 907 1991 PLEASE HELP ME!!!!!
Posted: Fri Nov 19, 2010 11:37 pm
by DUCATENO
Hi, again.
Still have my queen DUCATI 907........... runs really great!!!! now i`m living in Mèxico City and when i get a ride in the city everubody look the bike!!!!
Now fuel economy its normal!!!!
Thank you for your post`s
Regards to all
Posted: Sat Nov 20, 2010 1:01 am
by Tamburinifan
Wow, here again after five years!
Welcome back!
So, what is the whole story on fixing fuel economy?
Posted: Sat Nov 20, 2010 8:58 pm
by nnnnnnorman
