Need part# for clutch plates for 87 PASO750
DALTON750PASO
Post by DALTON750PASO »
Dose anyone have a link and a part number to replace the clutch plates on the 1987 PASO750? thanks
DaveM
Re: Need part# for clutch plates for 87 PASO750
Post by DaveM »
# 19020051A Clutch plate kit = £71.68 from Ducati dealer in UK
DALTON750PASO
Hi found it at http://translate.google.com/translate?h ... %3D1I7SUNA
But it says its for a oil clutch?
And at http://www.xtremetoystore.com/eshopprod ... DUCATI.htm
But at $309.10 a kit # FERODO CLUTCH KIT FCS0671
455-1160 Check Fitment Guide.
DaveM
Post by DaveM »
:o the kit i have is not for a wet/oil clutch & they are the same as the old clutch plates i replaced when i did my clutch and the part # is 19020051A and they work perfectly no problem. I hope you get yours sorted ok.
check this thread " clutch...DaveM " in " 750 paso discussion"
