DUCATI PASO 750 & 906 NEW RUBBER FAIRING NUTS
Posted: Tue Aug 19, 2008 1:02 am
by 20YearOwner
I have extra fairing nuts if you need them. I can post to USA only. $2ea.
DUCATI 750 & 906 PASO New Replacement Rubber Nuts.
Replacement rubber with brass inserts to fit the bodywork, fairing upper & lowers, side covers and turn signals PASO models 6MM.
Re: DUCATI PASO 750 & 906 NEW RUBBER FAIRING NUTS
Posted: Sat Aug 23, 2008 11:07 pm
by paso_rosso
PM sent! i could use a few!!
Posted: Thu Mar 05, 2009 1:03 am
by Horse
You have any left? If so please PM me. Horse.
Posted: Thu Mar 05, 2009 2:33 am
by samandkimberly
Horse wrote:You have any left? If so please PM me. Horse.
you can buy separate well nuts, or a whole Paso fairing bolt kit here:
www.bikebolts.com
I helped him put the kit together so I know it fits a 907ie perfectly. I don't think there's any real difference in the fairing fasteners between 750/906/907.
Posted: Thu Mar 05, 2009 10:41 pm
by Desmo_Demon
20YearOwner wrote:Replacement rubber with brass inserts to fit the bodywork, fairing upper & lowers, side covers and turn signals PASO models 6MM.
I have aftermarket fasteners on my Paso.....are these wellnuts standard M6 welnuts? If so, here's a source where they are $0.70 each...
http://www.desmoparts.com/ducati/wellnut/wellnut.htm#
Posted: Fri Mar 06, 2009 12:15 am
by higgy
M6 wellnuts are not hard to find,Home depot has them as well as many industrial supply houses
.70US is not a bad price
Posted: Sat May 02, 2009 9:25 am
by ducapaso
Yellow bolts are also available in Ducati: here's the one for the ST2 front mudguard:
Sorry for my dirty fingers!!!
Posted: Sun Nov 15, 2009 2:23 pm
by joelbb115
After finding the 6MM well nuts on-line for $0.70, with a shipping/handling of $7.00, that was the best deal I could find, but the shipping charges killed it (only needed 6 of them).
I did find them at Lowe's in the hardware section, pretty cool as I had called nut and bolt specialty places, and hardware stores and neither had them. They were $0.92 each, and worked perfectly but if you need more than five, you may have to visit multiple Lowe's because each store will only stock five of them.
Posted: Sun Nov 15, 2009 3:17 pm
by higgy
In the states you can find them at MSC or McMaster Carr and many Ducati aftermarket sources as well.
Posted: Wed May 18, 2011 2:57 pm
by cellardoor
Wow thank you! I have been looking for wellnuts for a while, Lowe's saved me from buying a complete and overpriced set of fairing bolts! this would be a good one for the tech faqs...
Posted: Thu May 26, 2011 7:51 pm
by persempre907
http://cgi.ebay.com/ebaymotors/25-M6-1- ... ccessories
...and a good source for some black anodized M6 bolts?
Posted: Wed Jun 01, 2011 10:12 pm
by ducapaso
Francesco,
Any suggestion for Ebay Italy?
Posted: Thu Jun 02, 2011 7:12 am
by ducapaso
Here it is! I've been lucky in finding, in the next days I'll tell you the price they asked me
http://annunci.ebay.it/annunci/ricambi- ... 3#rispondi
Posted: Thu Jun 02, 2011 10:53 am
by higgy
Posted: Tue Dec 11, 2012 9:07 pm
by 20YearOwner
Update on well nuts:
I found a source for an auto well nut that fits the Paso.
Made by Au-ve-co Products they are located in Cold Springs KY, 41076 USA
Well Nuts, Box of "50", Part #13003, Size M6-1.0
https://www.auveco.com
On the website search for part number 13003.
