number of chain links ?
Posted: Sat Sep 06, 2008 7:57 am
I recently looked through a fitting chart from REGINA chains and got confused. It says:
750 Paso 87
15-38-106 (530)
750 Paso 88-90
15-38-110 (520)
906 Paso 89
15-40-108 (520)
906 Paso 90-93
15-38-106 (520)
907i.e. 90-91
15-40-108 (520)
907i.e. 92
15-40-108 (520) but with a different order number
Now I guess there must be some things wrong here. I can understand that with a 40 tooth sprocket a chain is used that is 2 links longer, but I`m wondering that the 907ie uses the same chain length as a 906 although it has a longer swingarm and I also think the data regarding the P750 is mixed up.
What`s the correct chain length for a P750 (520 chain) and a 907ie ?
750 Paso 87
15-38-106 (530)
750 Paso 88-90
15-38-110 (520)
906 Paso 89
15-40-108 (520)
906 Paso 90-93
15-38-106 (520)
907i.e. 90-91
15-40-108 (520)
907i.e. 92
