donaldo duck!
Posted: Mon Sep 15, 2008 2:37 pm
tell us about the rear brake conversion on your bike.
You can count the holes though. There are 12!paso750 wrote:brake conversion ? Isn`t that the standard brake of the 907ie just with countless holes in the caliper mounting bracket ?
Exactly! Easy way to make my bike different from any other 907ie or Paso. All polished original parts except the custom exhaust.Tamburinifan wrote:I think the answer is:
BLING!!!![]()
Standard caliper bracket w a few holes & polished.
DonaldoDuck wrote:Thanks for the question, but they are the stock goldline Brembos that came on the 907 in 1992.
You can count the holes though. There are 12!paso750 wrote:brake conversion ? Isn`t that the standard brake of the 907ie just with countless holes in the caliper mounting bracket ?Jeez I took your metal as a 750 didnt I should av got a 907ie seems like the finished paso! must jump into the forum for this bike maybe ill change to one then if i can find one,thanks again desmodave.
