tyre pressures
Posted: Mon Sep 22, 2008 11:43 am
by desmodave
what are the correct pressures in p.s.i for the michelins ive seen 33 and 38 somewhere but are these for the pirellis?
Re: tyre pressures
Posted: Tue Sep 23, 2008 8:56 am
by amphilex
Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi.
http://two-wheels.michelin.com/2w/front ... 4a424b424a
:thumbup:
Re: tyre pressures
Posted: Tue Sep 23, 2008 11:35 am
by Desmo_Demon
I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds).
Re: tyre pressures
Posted: Tue Sep 23, 2008 2:35 pm
by desmodave
amphilex wrote:Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi. Thanks for reply i'm not too far out eh? the rear is important because of the pillion and load!
:thumbup:
Re: tyre pressures
Posted: Tue Sep 23, 2008 2:37 pm
by desmodave
Desmo_Demon wrote:I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds).
Thanx sounds like your sorted! cheers dave.
