Paso mirrors (again...)
Posted: Wed Sep 24, 2008 8:06 pm
Has anyone successfully repaired any original Paso mirror pods?
Over the past couple of years I've collected some battered pods, all of which are in need of repair. Indicator lenses are still available, while the mirror glass can be replaced with one from a Suzuki mirror - I don't know which model, I've just asked for a match at a motorcycle breakers.
In each case the inner metal frame and circular mirror surround has come away from the shell of the pod. I can see how the whole lot fits together, with the metal frame locating in a small plate in the front of the shell, but can't see what stopped the whole assembly coming apart again. On one of my pods someone has glued the circular surround to the shell, while on another someone put a small nail thru the surround and shell then painted over the head!
Any suggestions please? At the moment I assume that the surround is just a tight push fit onto the shell but comes loose if the pod is damaged.
Martin Philp
Paso 750
Martin Philp
Paso 750
