Converting our beloved PASO’s 750/906 from 16” wheels to 17”
Posted: Tue Oct 21, 2008 9:18 am
by nilaus
As we all are aware of, we all have a issue, problem, dilemma………. lets call it a : task, in converting our beloved PASO’s 750/906 from 16” wheels to 17”. I think it could be very interesting and inspiring, if the guys, who have done the conversion, could make some kind of “this is how I did it” maybe also with pictures in some kind of sticky topic or alike.
I am in the mist of the converting to 17”, and I have all the basic hardware, such as wheels and brakes. I also have a plan on how I want the end result, but it is also nice to see what others have made, and what problems they have ran in to.
Just a thought.
regards
Klaus
Denmark
PASO 750, 1990.
Re: Converting our beloved PASO’s 750/906 from 16” wheels to 17”
Posted: Tue Oct 28, 2008 11:49 pm
by Mc tool
54 views and no replies, what a pack of fence sitters ! just the motovation I needed
I have a 90 paso 906 and a 97 900ss and after reading this post and deciding that the 8 rear and 6 front 16'' michelins I have stock piled aint going to last for ever , I got the tape measure out and had a quick measure up , got a bit excited , rolled a little " inspiration " and the spanners started flying . I removed the whole front end of the paso , tripple clamps forks , brakes , the lot . I then did the same to the ss, removing the top clamp , the steering head nut and removed the master cylinder assy ( without disconnecting any hoses ) and removed the whole assy in one piece , wheel , forks, brakes, lower clamp and hugger, fitted the whole lot to the paso, fitted steering head nut and top clamp. The only issue is the handle bars as the clip on's off the SS deffinatly wont fit the paso. Yahoo , up side down forks , 4 spot brembo,s 17,s.................... it all fits, now all I got to do is find enough SS bits to make it a perminant fix as I just couldn't rape the SS like that but it all works ( without actually going for a ride ) . The ofset on the tripple clamps is the same too , so no change in steering geometery
Posted: Wed Oct 29, 2008 8:45 am
by paso750
this happens when people doublepost. Check the same thread in zhe P750 forum.
very strange. I had SS tripleclamps and they were definetely different. The ones that came close regarding offset were the ones of a 900SSie, but the didn`t work with the forks I had. Steering geometry is unlikly to remain the same as the forks are shorter.
Posted: Thu Oct 30, 2008 4:45 pm
by Desmo_Demon
Mc tool wrote:and removed the whole assy in one piece , wheel , forks, brakes, lower clamp and hugger, fitted the whole lot to the paso, fitted steering head nut and top clamp. The only issue is the handle bars as the clip on's off the SS deffinatly wont fit the paso.
This is interesting because I cannot do this with an '87 or '88 Paso 750 and the front end from a '94 SS900cr with the non-adjustable SHOWA forks. The steering stem on the Paso is 25mm in diamater and the steering stem of the '94 SS900 is 26mm. The steering bearings on the Paso 750 are 25mm x 47mm x 12mm and there are no taper roller bearings that seem to exist with the dimensions of 26x47x12. What is the diameter of the steering stem of the '97 SS900? If it is 25mm, I may have to look into finding a lower triple clamp with steering stem from a newer SS. I'm been hesitant to pull the stem off the Paso triple and swap it with the SS900 stem.
Posted: Thu Oct 30, 2008 10:50 pm
by Mc tool
Uh ok I had taken a bunch of photo's but gave up trying to post them ( I have since seen the post by J slocum so will try again ) . I will have a good measure up this week end and provide better details. I didnt change the steering berrings so I had the inner race on the ss lower clamp and the paso outer race in the frame . I had trouble getting a ( non genuine ) berrings for the ss and I think I wound up getting a fiat wheel berring kit , may have been the paso as I have done them both recently . Can you remove the stem from the lower clamp ? the one on the paso had been butchered by someone trying to remove the lower berring with an angle grinder and I wound up getting it built up and reground to size bit now it isn't quite straight ( ho hum la la lala la )
Posted: Fri Oct 31, 2008 2:53 pm
by Desmo_Demon
Mc tool wrote:Can you remove the stem from the lower clamp ?
Yes, you can press out the steering stem from the lower triple clamp if you heat the triple clamp fairly well. Another member of the forum did the USD fork conversion on his bike and he pressed the Paso stem into the SS900 lower triple so he could attach the front end to the bike.
I'm not too sure about wall thicknesses, but I had given it a little thought to have the SS900 steering stem removed and turned down 1mm in diameter on a lathe. I don't know if that will make the stem's wall too thin, though, as I have not checked the thicknesses of the two stems. If it wouldn't cost an arm and a leg, I had given it some thoguht to have a machinist make a new stem (and I've casually been wtching eBay for a spare lower triple clamp with stem, also).
Posted: Fri Oct 31, 2008 7:56 pm
by Finnpaso
Mc tool wrote:Can you remove the stem from the lower clamp ? the one on the paso had been butchered by someone trying to remove the lower berring with an angle grinder
I did just that way in my another 907 few days ago, cause it seemeed to me only way, because i didint had enough good tools to remove all bearing parts.... I realized again, that if doing ALLKIND maintain works and preparings, need then very good / expensive tools...
:smoke:
Posted: Mon Nov 03, 2008 2:43 pm
by f1steveuk
http://cgi.ebay.co.uk/Ducati-906-Paso-1 ... 240%3A1318
Nice conversion on Ebay UK, Yamaha Thunderace, and it looks good too!
Posted: Mon Nov 03, 2008 4:48 pm
by paso750
if converting and the bike is red I would take the wheels of a Bimota Furano. I think they are amongst the nicest wheels, look a bit like the Marvics and should match the bikes design better than i.e. Marchesini wheels. (once in a while a set shows up on ebay)
Posted: Mon Nov 03, 2008 6:01 pm
by mike
those are beautiful. that would definitely be an acceptable solution keeping with the design theme of the bike. :thumbup:
