Rear Sprocket
Posted: Wed Oct 22, 2008 10:41 pm
by englishstiv
Will a 750/906 rear sprocket fit on the wheel of a 907. Is it a different size/width etc? I know the wheels are different so are the hubs and the carrier for the sprocket?
Tried the search in the General Forum without any joy.
Re: Rear Sprocket
Posted: Fri Oct 24, 2008 7:25 pm
by Finnpaso
750 and 906 have same sprocket system, but 907 have totally anotherkind (like Monsters, etc have), so 750/906 rear sprockets DONT FIT TO 907 at all.... its easier to find right rear sprockets to 907, than to 750/906... Monsters "range" is very wide, so U have to choose from them right to Your 907.....
Re: Rear Sprocket
Posted: Fri Oct 24, 2008 10:59 pm
by englishstiv
Thank you Antti
Re: Rear Sprocket
Posted: Sun Oct 26, 2008 4:49 am
by persempre907
...and for the front sprocket?
If I well remember the 907 front sprocket has some "offset" so is quite tricky to find.
Re: Rear Sprocket
Posted: Sun Oct 26, 2008 10:54 am
by Finnpaso
My opinion is, that ONLY original Ducati OEM 15 teeth sprocket fits 100% with right offset.... It can be also, that some of those big USA Ducati dealers, like Ferracchi have some own sprocket solutuin to front. Anyway its very easy to change rear sprockets (from Monster range, where range is very wide for rear). Some 900 Monster have very close same offset, as 907 have in front, was it some 2001, or so.. remembering now only!
Re: Rear Sprocket
Posted: Tue Oct 28, 2008 3:25 pm
by Tamburinifan
Think you´re right there, Antti, 2001 was the year w the longer Hyper gearshaft and therefore sprocket
w a special offset f 900 Monsters.
Re: Rear Sprocket
Posted: Tue Oct 28, 2008 5:21 pm
by persempre907
Finnpaso wrote:My opinion is, that ONLY original Ducati OEM 15 teeth sprocket fits 100% with right offset....
It seems to me they are still available. The brand is AFAM if I well remember.
Could someone confirm it?
Re: Rear Sprocket
Posted: Tue Oct 28, 2008 8:06 pm
by Finnpaso
I can only confirm, that original 15 sprockerts are still available, cause i get some from Italy some monthes ago. They are OEM parts.
