Swingarm bearings
Posted: Thu Nov 06, 2008 9:51 pm
by JWilliam
I replaced the swingarm linkage bearings last year but they are as bad as the ones I took out now. So what MFR makes the bearings for Ducati? No point buying more of the same, but no point asking Ducati because they don't list spares for the 906.
Re: Swingarm bearings
Posted: Fri Nov 07, 2008 8:53 am
The old ones I had removed were from INA.
Posted: Fri Nov 07, 2008 1:05 pm
by Desmo_Demon
paso750 wrote:The old ones I had removed were from INA.
With the dimensions, I'm sure you can buy some SKF or other brand bearings.
Posted: Fri Nov 07, 2008 1:07 pm
sure, see 750FAQs for alternatives
Posted: Sat Nov 08, 2008 1:33 pm
by Laddie907
INA are extremely high quality bearings...in fact INA are about the ONLY high quality needle / cylindrical roller bearing company I know of...
I strongly suggest the HIGHEST quality lubricant for the swing arm bearings; they are subject to fretting corrosion and minor galvanic current. it might be a case for something like Lanotec grease.
Posted: Sat Nov 08, 2008 2:31 pm
by Finnpaso
Its ALSO very important to put very good quality seals to swingarm system, not only bearings. There are many seals also, what are against shit going inside bearings..... remembering, that 6 of one size and 2 another size. High pressure water washer is one of worst things to such bearings..... same with wheel bearings!!!!! I never use such machine with washing my Ducatis, no matter i have such! Only for car cleaning.... from mud! :thumbup: :smoke:
