Page 1 of 2
WTD 907 swing arm
Posted: Wed Jan 07, 2009 4:47 pm
by jpiepho
Looking for a swing arm in the US to fit a 91 paso.
Re: WTD 907 swing arm
Posted: Wed Jan 07, 2009 11:36 pm
by higgy
I have one for a 906, needs to be cleaned up and anodized, has some battery acid stains but structurally excellent
Posted: Thu Jan 08, 2009 7:59 pm
by jpiepho
How much do you want for it?
I don't mind cleaning it up butI don't know about how to go about getting it annodized.
Posted: Thu Jan 08, 2009 8:52 pm
by Kurt
A little off thread, since it's not about your swingarm, ... I was thinking of getting mine polished -- has anyone done that? Might send the footpegs out, too. Not original, I know, but I like the look of slowly fading polished aluminum ... (to each his own, there's no accounting for taste, etc.)
Posted: Thu Jan 08, 2009 10:48 pm
by persempre907
jpiepho wrote:I don't know about how to go about getting it annodized.
I guess it's difficult and expensive.
I also have some battery leaks on the footpeg and the swing arm...
Posted: Thu Jan 08, 2009 11:30 pm
by higgy
actually anodizing itself is not that expensive or difficult if you have access to a good voltage source( right kind of battery charger will do)
but it would certainly be easier to have it polished and sealed with a good durable clear coat.
On the subject of the 906 swingarm I have, I would prefer to barter but we can work something out in our mutual interest if you like
Oh I am partial to beaded aluminum finishes and grained stainless
btw,bevel heaven has canisters you can add to your bike to prevent battery acid stains to begin with...........
Posted: Fri Jan 09, 2009 6:38 am
by ducapaso
higgy wrote:I have one for a 906, needs to be cleaned up and anodized, has some battery acid stains but structurally excellent
I'm not sure 906 swing can fit on a 907
Posted: Fri Jan 09, 2009 1:09 pm
by jpiepho
I don't mind a barter but my selelection of paso spares is limited.
I've got an original tail light & rear turm signals, a cracked but repairable mirror from a garage tip over & a used set of clutch plates that I think wil work if re-surfaced. Of course I need to look into the compatabilty of the 906 swing arm.
Posted: Fri Jan 09, 2009 2:05 pm
by paso750
forget that. It doesn`t make any sense to put a 750/906 swingarm in a 907ie. It would fit but it`s shorter as it`s not made for 17" wheels. Rear axle diameter is also different (20mm on 750/906, 17mm on 907ie)
Keep the mirror or have someone repair it if it`s an original clip-on one as it`s quite valuable.
Posted: Fri Jan 09, 2009 2:41 pm
by jpiepho
Ok, thanks for the advice...
I'll keep looking, if I can't find one maybe I can find someone to repair the damage to mine caused by the loose sprocket carrier bolts.
Posted: Fri Jan 09, 2009 3:52 pm
by Kurt
Hi. I think LOTS of these swingarms have been damaged that way, and have been repaired, too. There are some other threads here on the forum about it as I recall. It happened to my '92 907 that I bought new in '92, and the dealer replaced the swingarm under warranty. And when I bought my used '92 last year, after removing the rear wheel, I discovered a very nice weld bead repair of similar damage. Welcome to the club!
Posted: Fri Jan 09, 2009 4:36 pm
by paso750
Posted: Sat Jan 10, 2009 11:32 am
by higgy
http://www.focuser.com/atm/anodize/anodize.html
all about anodizing.
If you decide to replace your 907 swingarm I am interested in your damaged one in case I decide to go 17 inch
Posted: Sun Jan 11, 2009 9:38 am
by persempre907
Posted: Wed Feb 11, 2009 3:56 pm
by kalli
Hallo everybody,
i have a 907 paso swinging arm for sale. if anybody is interested late me know.
thanks
kalli
