Weber carbs bad
Posted: Fri Apr 08, 2005 6:06 pm
by MetalHed
If weber carbs are all pretty much crap, what would be a good carb to use for the bike? 1988 Paso 750. Does anyone have a carb other than weber or dellorto? How good does it work?
Posted: Fri Apr 08, 2005 8:43 pm
by Skins
Can I suggest that you do a search of our site on the subject? People say the Weber can be made to work with a fuel pressure regulator. There is already a lot of information here. If you can't find what you need, ask again.
Posted: Sat Apr 09, 2005 3:54 am
by fasterdammit
I started a similar thread a while ago too
here that garnered some good info. But like Skins said - do a search, even through this site, and you'll find plenty of discussion.
Personally, I'm working on finding a set of Monster 750 Mikunis to swap in, I think ... we'll see. Whatever happens, I'll post up about it.
Let us know what route you take, if any, too![/url]
Posted: Sun Apr 10, 2005 1:35 am
by Rodney
weber carb when set requires very little mateinance just the occasional cleaning out ,it just seems to be the irregularity in the fuel pressure that causes the problem .
Rodney
