Paso 750 Rear Tire solution (160/60/16)
Posted: Wed Feb 04, 2009 7:52 pm
Hi Folks,
I just wanted after a few years to ra-activate my Paso750 and faced soon with the tire problem. The tire which I have mounted is almost new, but I belive almost 10 years old.
First I mailed Ducati Switzerland, once, twice, no reply. Then I tried it at Ducati.com, just a stupid answer, to put it straigth in words: No interest throw it away. Shitty service, dont await any help from there. I belive If they would put some effort on it, we still would have tires.
Next solution move to 17", just to comlicated and to expensive. In adittion I probabely would not pass the official control Inspection (MFK), where I have to show up befor I can drive it again. And releases are rather difficult to get (no release from Ducati).
Therfore I just searched for similar tire dimensions, an found several 180/60/16 tires (mainly Touring tires for Gold Wing) which fit on the Paso rear wheel (5")
I afterwards sized the situation out on my Paso. Swingarm O.K. wide enough. Altitude taff (180/60/16 is 12mm higer than the 160/60/16), but if you put the weel in the middle position or behind, it should work. Chain: problem!!! There is just about 5mm space between Chain and tire.
Solution: Put a spacer (7-8mm) at the inside of the Chain Sprocket (Ritzel) to get it to the left (from behind), organise a big ring washer to fix the sprocket. The axle has a thred inside, so you just need the matching screw.
At the rear you put spacers (5-6mm) inbetween the weel and the Crown (on the screws). That should be enough to have a little space (2-3mm) between the chain and the 180 tire. I know it's not much ....but should work.
The only thing which I do not really know is how the tires behave....
The tire options are:
-Bridgestone G 704 180/60 R16 TL 74H special für die Honda Gold Wing GL1800 ; Radial; up to 210
-Dunlop D 250 180/60 R16 TL 74H M/C; Radial; up to 210
-DUNLOP ELITE 3 REAR TIRE 180/60-16 - SR180-16 RADIAL up to 210
-two Avons which i did not like much..
I just asked a Gold Wing dealer weather he could recomend one of the tires, but he ment they are more or less the same. I prefer Dunlop, but I think that's something which has to be figured out how the tires behave on a Paso. I belive should not be a problem, I anywav never liked the original michelin ... no grip before tey really had the temperature (on could asphalt almost impossible), like driving on soap on wet conditions.
In front I would suggest a 130/70/16. There are several nice tires available. I always used to mout a 120/80/16 which was a very good solution, but ther are no Radials anymore available in that dimension.
So, thats the suggestion I have. I belive very easy solution,(just nees a few spacers, a ring washer) , and should be not very expensive. The Risk is approx. 300$ (250 tire, 50 Spacers/Ring washer).
As i still have to show up at the official control Inspection (whit the Original tire), I'm probabely not going to do the conversion before May ore June. If any of you think it's worth to try, I would be glad to know how the tires work. I'm shure the rest works as described. It's alredy some years ago, but I used to work as a mechanic. It's not the first problem to be solved...
Good Luck
Good Luck
