New Member
New Member
My name is Volker and I’m coming from Germany. Since 15 years I’m riding and owning several Ducatis.
Several years ago I bought an 88 model of the 750 sport, still in the original colour pattern of the first production lot. Yes it’s one of the rare red-blue-white bikes.
Today the colour pattern is still the original one. Since the bike was in a good overall condition I decide to modify only the parts that have to be changed:
• Rear Damper
• Brake hoses
• Wind shield , now a black one
• Repaint the lower part of the fairing in the original red
I’m still riding the bike with the 16”er and hoping to get new tires in the future.
I’m not so skilled in writing English, so excuse all my grammar and writing mistake.
Unfortunately I didn’t find the possibility to add a picture of my bike.
At the moment the bike is not running, because the ignition switch is broken and I’m not able to find an original spear part. Is anybody using the ignition switch of the following model (SS91-97) and what have you to change to get is run with this part?
Greeting from the south of Germany
Volker
• Rear Damper
• Brake hoses
Volker
Re: New Member
Hi Volker,
Did you try to fix the switch ? In numerous cases it is possible.
here`s how to
http://www.box.net/shared/4evp1px5be
If the Sports ignition switch has the same connector as the Pasos ignition switch it`s square with round pins. The connector of the SS switch is wide and has flat pins as far as I know.
Gruß,
Gerhard
here`s how to
Gruß,
Gerhard
Kurt
Re: New Member
Welcome. I've found this to be a good group, very willing to help.
As to your English, au contraire, I'd say you are very skilled in it, no need to apologize.
- Kurt
- jcslocum
Re: New Member
Volker, There is directions on how place pictures in your posts at the top of the forum main page. It's not hard to do once you know how.Bag wrote: Unfortunately I didn’t find the possibility to add a picture of my bike.
Volker
Welcome to the site. I hope you find all of the info that you need.
Re: New Member
Short test to add a photo of my 750 sport
Gerhard, my ignition switch looks different to the one shown in the description.
I will try to make a photo later.
Kurt, I still find taking to somebody much easier than writing an email or post.
Greeting from Germany
Volker
Volker
- ducinthebay
Re: New Member - Paint
That paint job always looked a bit like a Union Jack to me. Was there a Brit on the design team? I think they were aiming at the US and British markets, but oddly, that paint job never made it to the States.
I think it would look really good if you switched all the blue bits to Italian Green. That would fix it straight away. And there would be no mistaking where that bike came from. For and easy trial, you can get some green reflective tape which is close to the right tone.
Nice bike though.
Nice bike though.
- Mustang505
Re: New Member
Hello Kurt
looking at your sport makes me wonder if i shoudn't rebuild mine back to original. It can look quite good. I see yours still has the original pipes? Does it have an aluminum swing arm, as our models suffered from cracking?
Clive
Clive
Kurt
Re: New Member
Hello, Clive, that would be Volker's Sport ... hard to keep all these German names straightMustang505 wrote:Hello Kurt
- Kurt
- jetboy
Re: New Member
i kind of like the colors, definitely unique which is a plus.
as for the ignition switch, i believe, though not certain, that mine is from a honda. I'm hoping to get an oem one soon, but if you just want to ride, petty much any switch will do the trick!
- Mustang505
Re: New Member
Hello Clive,
now problem at all
I still use the original mufflers at my sport. They sound okay and are legal for road use. With loud pipes you got soon problems with the german police.
The swing arm is an aluminum one simular like the one used at the limited models of the F1. Till now I have no problems with cracks so far.
Volker
now problem at all
Volker
- Mustang505
Re: New Member
Hi Volker
have a look at my post there some pics of my sport - looks identical to yours. The pipes on it before I stripped it down were very loud (when i could get it to run!!) so they won't be going back on. If I return it to original I'd like to get some pipes made up like yours.
Clive
Clive
- jcslocum
Re: New Member
Are those just Paso mufflers??
Re: New Member
no, although they generally look the same
Re: New Member
The name or number on the mufflers are A01 and B01.
Volker
Volker
