907 IE Exhaust
Posted: Tue Mar 10, 2009 10:33 pm
I have loud pipes on my 907 now and I found the original factory pipes on Ebay and bought them cheap.Can I just put them on without any jetting or changes.Thanks...
macwig,macwig wrote:I have loud pipes on my 907 now and I found the original factory pipes on Ebay and bought them cheap.Can I just put them on without any jetting or changes.Thanks...
No, aftermarket cans dont make any more power, but that CHIP (to added to them) makes that "more power", if its suitable and bikes injection system is tuned well.... Power comes from MORE fuel(and surely more air), better flow characters(engine "breathing").... Its little funny, that aftermarket exhaust sellers tell often, that you can get more power with they pipesmrinflux wrote:macwig wrote:The aftermarket cans provide more horsepower
Finn,Finnpaso wrote:No, aftermarket cans dont make any more power, but that CHIP (to added to them) makes that "more power", if its suitable and bikes injection system is tuned well.... Power comes from MORE fuel(and surely more air), better flow characters(engine "breathing").... Its little funny, that aftermarket exhaust sellers tell often, that you can get more power with they pipes.
That's the truth, so it's also true (according with the magazines I read) that sometimes the aftermarket cans get less power than the stock ones.mrinflux wrote:An aftermarket exhaust alone (with no other tweak) will change very little to nothing. The engine may aspirate better but it will not produce more horsepower. Actually it will run lean (still speaking of an original untouched bike). If you then reprogram the Eeprom to match the exhaust you will get more fuel in the compression chamber. That is when you will get more power.
I agree 100%paso750 wrote: An aftermarket exhaust alone (with no other tweak) will change very little to nothing.
I agree 100% again...paso750 wrote:The engine may aspirate better but it will not produce more horsepower. Actually it will run lean (still speaking of an original untouched bike).
I agree 100% again , maybe i would say, that i agree this "200%"paso750 wrote:If you then reprogram the Eeprom to match the exhaust you will get more fuel in the compression chamber. That is when you will get more power.
paso750 wrote: Although Antti likes to be provocative sometimes
My remarks w bigger letters.Changing the exhaust and remapping the eprom alone will
1 make more noise
2 make the engine produce less power 1
There is nothing to discuss or anything worth arguing about. It is a simple proven fact. Period
Now if you change the exhaust with a corresponding change to the intake airflow and the proper remapping of the eprom it is possible to wring out a little bit more power. a few ponies more
Adding more fuel will just make your engine run richer.
Internal combustion engines run on air.
to get more power you have to get more air into the engine or compress the air more. That's it there is no other way.( well almost no other way,there is always accelerants like oxygen)
Fuel is simple the agent used to heat the air. Fuel will only heat the air properly at 14.7 2 to one That is 14.7 units of air to one unit of gasoline by mass.
Generally it will take more than remapping and Exhaust and intake mods to get a real increase in power. 3 Cam timing needs to be considered to get real improvements and most of those kind of improvements require higher rpm, but raising compression is still the best way to go.
