Coolant tank...
vee2duc
Coolant tank...
Post by vee2duc »
Does anybody know how much collant (ltr.) is inside the tank? :?:
750ss´92 (1996)
996´99 (2004)
Paso 906´90 (2009)
gail
Re: Coolant tank...
Post by gail »
3.3 litres total in system and 275 ml between top and lower level marks in tank, ... Marty
vee2duc
Re: Coolant tank...
Post by vee2duc »
Thanks... :thumbup:
750ss´92 (1996)
996´99 (2004)
Paso 906´90 (2009)
Re: Coolant tank...
It will be very hard put all 3,3 litres of coolant into the circuit, because some coolant will remain into the circuit.
Howewer, you have to unscrew the tank from the frame and raise it to put the water into the circuit.
In fact, the tank is not the higher point of the circuit, so if you don't raise it you will not manage to get the water into the circuit.
