Alternative oil filter
Posted: Thu Apr 16, 2009 1:09 am
by Duc906
I did an oil change yesterday and since I'm 3 1/2 hours from the nearest Ducati shop I went for an alternative oil filter.I used the parts interchange as a guide with no success,but what I did find was that this filter from Ryco was almost identical to the original.
http://www.rycofilters.com.au/catalogue ... t/part/z93
Re: Alternative oil filter
Posted: Thu Apr 16, 2009 5:19 am
by vee2duc
The filter for Citreon 2CV fits also...
Posted: Thu Apr 16, 2009 7:28 am
by Duc906
vee2duc wrote:The filter for Citreon 2CV fits also...
I tried to find one of those but Citroen 2CV's are as rare as rocking horse s@#t over here and so are their oil filters.
Posted: Thu Apr 16, 2009 11:05 am
the first ones I used where the same as on most old Alfas and Fiats (ie Alfetta or Fiat Tipo). Mine were from CHAMPION
Posted: Thu Apr 16, 2009 8:55 pm
by vee2duc
HIFLOFILTRO HF153
from my distributor for about € 4.-
Posted: Thu Apr 16, 2009 10:46 pm
by ducapaso
beware of not OEM filters!
Some of them have (or need) a "non retourn" valve inside and this might cause serious pressure troubles to your engine!
Posted: Fri Apr 17, 2009 12:23 am
by Duc906
ducapaso wrote:beware of not OEM filters!
So does the original filter have a non return valve in it?
Posted: Fri Apr 17, 2009 5:20 am
by ducapaso
Actually I don't remember...
Otherwise I'm SURE that old "alfa romeo Alfetta" has a huge filter w/o valve and "Alfasud / alfa33 /alfa 145" has it.
Posted: Fri Apr 17, 2009 8:50 am
by Finnpaso
I use FRAM PH2839 about 5.50-6.00€
No problems ever and made in EU
Citroen 2CV and some older Talbot use same filter.
Posted: Sat Apr 18, 2009 12:45 pm
by persempre907
Unfortunately, I doubt the spares (so, the filters) for FIAT, Alfa Romeo, Citroen and Talbot were easily available in Australia...
Posted: Sat Apr 18, 2009 10:58 pm
by jcslocum
I have a buch of the K&N which is a very nice filter. The club buys them at about $8.10 each. Just ordered 45 of them!
Do you need one? I can mail it to you.
Posted: Sun Apr 19, 2009 12:06 am
by Duc906
jcslocum wrote:Do you need one? I can mail it to you.
Thanks Jon
But I've already fitted the Ryco filter.I took the bike for a decent ride yesterday to test all the tyre mods that I've done and had no dramas with the oil filter.
Cheers Ken
Posted: Sat Apr 25, 2009 3:17 am
by dave906
Hi Ken, have just seen this post. I've used Ryco Z93 for years and had no problems.
cheers
Dave
Posted: Sat Apr 25, 2009 8:42 am
by Duc906
dave906 wrote:Hi Ken, have just seen this post. I've used Ryco Z93 for years and had no problems.
cheers
Dave
Thanks for the feed back Dave,I was still a bit worried weather it was going to be ok or not.
Posted: Sat Apr 25, 2009 2:52 pm
by JWilliam
Halfords (Great Britain) now have a line of motorcycle accessories and that includes oil filters for all Ducatis.
