suddenly won't start.
Posted: Tue May 05, 2009 8:40 pm
This just happened so I have not gone through everything yet, but figured id ask if there was some interesting thoughts on the starting system. its been converted to dellorto carbs.
the story is: running alright, possibly not the best mixture, but always started right up -
I parked it after a short ride, and then I replaced the speedometer. after replacing I went to start her up to see if all was well, and she wont start. I checked the plugs, am getting spark, I changed the plugs just to be sure-- nice blue spark in both. I charged the battery in case it was not pushing enough amps-no help. it does have gas, and gas is making it into the carbs- i can hear the pump going- and when i removed a fuel line there seemed to be plenty of gas I have not yet tried starter fluid, i probably will do that later today.
I guess the question is, anything else it could be? I have spark, gas, and compression-- but something in the mix is suddenly off. I suspect it might be my choke- ive had to mess with those cables a bit recently and I noticed that the PO had it set so that the cylinders are not at 100% "in" even when the choke is not engaged. its more like 80%. I am not sure if this is supposed to be this way.
any grand wisdom?
-j
any grand wisdom?
-j
