Check your rear shock!
Hello All,
I have owned my 1989 906 Paso from new and last week I took it for its annual MOT check. The tester mentioned a small amount of play in the rear suspension unit which we guessed was due to some wear in the upper bush mounting. Yesterday I investigated it and had an unpleasant surprise when I found that the top 'eye' had a crack right through it:
http://docs.google.com/Doc?docid=dgv8c3 ... p&hl=en_GB
I have posted an appeal for a unit in the for sale section.
David Harvey - Sussex - England
Re: Check your rear shock!
How many Kms have the bike?
- jcslocum
Theres a shock on ebay right now. That might be able to be welded as well.
I don't know. I'd fear the welding could break again.jcslocum wrote:That might be able to be welded as well.
Hello All,
Many thanks for your replies. The unit is the original one and has covered 88k kms. I did wonder about having it welded but I would be worried that the 20 year old alloy would just break again somewhere else. I have had a look at http://www.hagon.co.uk and it looks like a suspension unit from a 916 will be a direct replacement. Can any one confirm this please? (If so, it will make finding a replacement on e-bay easier). For the time being I will try to source a replacement in the UK in view of shipping costs.
Thanks again for your help.
Regards,
David Harvey - England.
Regards,
definetely not. The shock of the Paso is much longer. (The one of the 916 is mounted on the upper side of the swingarm and is therefore shorter)it looks like a suspension unit from a 916 will be a direct replacement
crmac
Have you sorted the shock yet?
I had this happen on my 1990 Paso years ago. I had it welded and it's been OK since then.
mika750paso
Hello All,
Many thanks for your helpful replies. I have had my unit welded and touching wood, all is well.
The bushing in the shock had a crack or the whole upper part of the shock had a crack?some wear in the upper bush mounting. Yesterday I investigated it and had an unpleasant surprise when I found that the top 'eye' had a crack right through it
Hi Gert,
It was the alloy surrounding the upper bush that had a crack. I took a photo if you are really interested.
pictures are always helpful for the wannabe Paso enthusiast so they can know exactly what to look for in considering a Paso purchase.
I have a small amount of play, too. Will fix it this winter.
A pic would be nice to see what problems lies ahead of me....
and seasoned owners too
Hello All,
A photo of my formerly cracked (and subsequently repaired) shock can be found at:
http://docs.google.com/View?id=dgv8c3qz_342cffkbhf8
I must stress that there was no play whatsoever in either of the bushes (pretty good after 65,000 miles). The small amount of play was entirely due to the crack.
