WTB: Paso parts***UPDATED June 10th***
- fredskidoo
Hello all . . .
I am in need of some parts for my Paso 750:
Lefthand side oil cooler cover (attaches to fairing)****ACQUIRED
Rubber fittings for both oil coolers (in the fairings) **** ONLY NEED 1 SET NOW
Left side oil cooler (either side will do actually)****ACQUIRED
Fairing for headlamp****ACQUIRED
Left and right flasher/mirror assemblies****ACQUIRED
Battery strap****N/A
Rear brake foot lever with rubber
Front rubber gromet for gas tank to frame****ACQUIRED
Rear tail peice (on top of the taillight)****ACQUIRED
130/60 ZR16 front tire
Speedometer cable****ACQUIRED
Tachometer cable
Both oil filters
Weber carburetor rebuild kit
Rear fender/license plate holder
I AM interested in any other compatible parts you may have for sale as well - just run it by me.
Thanks!
Tachometer cable
Both oil filters
Thanks!
'87 750 Paso 751412
Re: WTB: Paso parts
there is no battery strap on the Paso.
You should add your location to your profile, that would be helpful if looking for parts.
- Harigeharry
Re: WTB: Paso parts
I got a complete Weber carb.
I might have a tail piece (have to look it up in the shed).
And a set of black wheels with tyres (front so so state, rear reasonable).
Re: WTB: Paso parts
How much for the weber?
- Harigeharry
Re: WTB: Paso parts
Don't really know what's worth.
When I look around on the web I see prices from around E100 (somewhere on this forum) till E300 when It's used on a Buggy or Fake American Musclecar.
Say E100?
Say E100?
Re: WTB: Paso parts
What is the serial number on the weber and do you know what jetting it has. For 100 euro it will have to have exactly what I am looking for to be worth the price
In particular I need to know which emulsion tubes your weber has installed. Be nice to know which auxilliary venturi tubes you have as well for future reference.
Also which main venturis.
- Harigeharry
Re: WTB: Paso parts
I'll look it up for you and post some pics...
Hope fredskidoo don't mind us doing business.
fredskidoo, Weber kits are available on ebay for a few dollars.
Re: WTB: Paso parts
most weber parts can be had at http://www.piercemanifolds.com/
They also are in California
- fredskidoo
Re: WTB: Paso parts
Update on WTB: Paso Parts.
As of today it looks like I have acquired:
tail piece
front tire
speedo cable
rubber gromets to hold oil coolers
Thanks to Higgy for the Weber link, Desmo_Demon for a speedo cable
and Ed at guzzitech.com for the tail piece.
No worries Harry and Higgy . . .
easy
tail piece
front tire
speedo cable
easy
'87 750 Paso 751412
- Harigeharry
Re: WTB: Paso parts
Its a bit dirty after 20 years of Paso service.
Absolutely no corrosion..
Re: WTB: Paso parts
very nice,but not what I am looking for,gonna take a pass..........sorry
- ducapaso
Re: WTB: Paso parts
It's ok, but how it looks inside?
You need to pull the cap!
ex...Red "smooth" 753349
- Desmo_Demon
Re: WTB: Paso parts
I have a spare brake lever, but I think it is a little bent, or something else may be wrong with it, but I forget. I'll check on it for you....fredskidoo wrote:Rear brake foot lever with rubber
I may have one of the front rubber grommets for the tank in my spares inventory. I'll have to look. If not, I can get you the dimensions so you can probably make one of your own.
You mean the spin-on filter and the prefilter screen?...The spin-on filter is the same as what the newer ones use, so you can find that at any dealer or buy an aftermarket filter, like a K&N KN-153 filter. The prefilter screen may still be available through Ducati but will probably be expensive. Finding anyone parting out a Paso on eBay, especially engine parts, may produce a person with one that will sell the prefilter screen to you.fredskidoo wrote:Both oil filters
I received your payment and will be getting the other parts out to you either this afternoon or tomorrrow. I'll shoot you a PM when they go out.
- year: 1986
Re: WTB: Paso parts***UPDATED June 10th***
Hi.
i have a few spares i am getting rid of,
-front fairing bracket
-front mudguard
-rear cowling
-headlight
-taillight (yellow indicators)
-rear footpegs
-rear grabrail (needs rechroming)
-repo near side mirror / blinker assembly (left hand side)
-near side handle bar (left hand side)
-fuel sender
-new brake lever
-new front sprockets x2
-new rear sprocket
-rear axle
-new rear disk
-brake master cylinder and lever
-original webers x2
-airbox
-used front disks
-wiring harness
-ventura rack
-staintune pipes
if your interested in any of these let me know
thanks
Rodney
-front mudguard
-rear cowling
-headlight
-rear footpegs
-fuel sender
-new brake lever
-new rear sprocket
-rear axle
-new rear disk
-original webers x2
-airbox
-used front disks
-wiring harness
-ventura rack
-staintune pipes
thanks
Rodney
