750 Paso Limited in Virginia
Posted: Thu May 21, 2009 1:53 am
by jcslocum
From Craigslist
$1800
http://roanoke.craigslist.org/mcy/1177042529.html
Needs some easy engine work but appears to be all there.
Re: 750 Paso Limited in Virginia
Posted: Thu May 21, 2009 10:18 am
by paso750
strange side fairings. No air conveyors, no side oil coolers
Posted: Thu May 21, 2009 3:35 pm
by jcslocum
I asked for more info
Posted: Thu May 21, 2009 9:22 pm
by persempre907
Very strange fairings.
I wonder if she's a real "limited".
Posted: Fri May 22, 2009 12:17 am
by jcslocum
from the current owner:
it was a running driving bike when i bought it a few years ago,but it had low compression,so i took the heads off and found bad valve guides,i took heads and cylinders to a machine shop and he removed the bad guides and cleaned up cylinders and told me to put standard rings back in.i have new guides and a bunch of new o-rings and gaskets,but never got back to it.you are right about the fairing,someone filled in the air scoops on the sides,but i bought originals on e-bay that will go with bike. i will try to take more pictures if you are still interested.
