oil drain plug
Posted: Mon Jun 01, 2009 7:22 am
by g.m.c.janssen
stupid question, but how to losen the oil drain plug? :banghead:
I used quite a lot force, but couldn't remove it. Should it open in the normal counterclockwise direction?
I used a 10 mm Allen wrench, but this seems a bit loose fitting. Is there a special size, 10.5 or so, needed
thanx
George
Re: oil drain plug
Posted: Mon Jun 01, 2009 9:51 am
by Tamburinifan
10 mm Allen, try to get a socket one.
Then try to hold it very firmly w one hand and and give a small but distinct punch w the other on the handle.
Re: oil drain plug
Posted: Mon Jun 01, 2009 12:09 pm
by Kurt
For certain, use a socket, make sure all is quite clean and that the wrench seats firmly by tapping it in place with a plastic mallet. The manual shows a torque spec of around 40 Nm for the drain plug, so that I think would be hard to break loose with a normal allen wrench. Also, the hole may be worn from years of use, so a new drain plug could be fitted. $12 from DesmoTimes, don't know the dealer price. Use a new washer, lube the threads with anti-seize ...
Re: oil drain plug
Posted: Mon Jun 01, 2009 2:49 pm
by g.m.c.janssen
Thanx a lot, the drain plug is lose now. It just needed a bit more force, but I didn't dare because I was not sure for the size of the Allen and direction.
Re: oil drain plug
by g.m.c.janssen
