Electrical Problem
Posted: Wed Apr 27, 2005 2:38 pm
by Theo
Hello, I thought I sent in a topic about my 88 750 paso but I cant find it now. Any way my bike now and then cuts off all eletrical power except when the key is almost in the locked postion then only th etail lights and headlight light dumby light comes on, only way I can get the ingnition on is when I hook up a volt meter to the battery or the regulator and starting solonoid just to check for volts then all is well that sounds kinda weird huh! I installed a new battery that didnt help either. Does any body here in the forum think if I due the wiring upgrade this fix the problem or any comments and help would be great.
Ride with pride
Theo
Posted: Wed Apr 27, 2005 3:35 pm
by jcslocum
Theo,
I sent a reply to your email but will cover it again here too.
ALL of the power is switched by the ignition switch. It most likely needs to be cleaned. You can remove it, take it apart and clean the contacts. It just depends on how handy you are.
The electical system on the Paso is crap. You need to clean the many connections to make sure it is in proper ( but poor) condidition. The only way I was able to overcome the many electrical issues that plagued my Paso was to modifiy the wiring. There is a thread that has some info on back a few months. I will email you the directions to make the mods direct.
Good luck.
Paso electrical problems?
Posted: Thu Apr 28, 2005 12:35 pm
by Theo
Thanks for your reply ,is this the wiring upgrade that you install new relays and a inline fuse and such?
Thank you
Theo
Re: Paso electrical problems?
Posted: Thu Apr 28, 2005 1:40 pm
by jcslocum
Theo wrote:Thanks for your reply ,is this the wiring upgrade that you install new relays and a inline fuse and such?
Thank you
Theo
Yes. Your email bounced back BTW.
Wiring worked great
Posted: Wed May 04, 2005 7:07 pm
by Theo
Thanks Jon
I did the wiring this past weekend. It took about 2hrs. Now my Paso runs like a race horse. Now if I could only stop the clutch from making that nasty scraping sound!
Thanks again
Theo
Posted: Wed May 04, 2005 7:47 pm
by Finnpaso
... so DONT DO ANYTHING to clutch!
Finnpaso
907IE
750Paso
Posted: Wed May 04, 2005 8:33 pm
by Gwenadu
My Paso is a 88 model (number 7543777) with Marelli ignition system. I am modifing the wiring -I have to adapt Jon advices (thanks Jon!) to this model, wires colors are sometimes different...-
Today the +supply of the digiplex is by the emergency stop button. I thing it could be fine to connect the digiplex on the outlet of the 2nd new relay with the coils. I could connect the red button between the battery and the (key) ignition switch (serie wiring) to keep it in use. The strenght in wire must be low enough now. My english is bad... sorry!
Posted: Wed May 04, 2005 9:18 pm
by Skins
Re the noisy clutch: Read the Topic 'New Bike' by motiztab. About half way through the noisy clutch comes up. Go to
http://www.users.waitrose.com/~paso/pasolist.htm#Clutch on the web.
Posted: Wed May 04, 2005 9:26 pm
by Skins
Gwenadu, your English is very good. If you use jon slocum's wiring plan, the kill switch (emergency stop botton) will still work.
Posted: Wed May 04, 2005 10:37 pm
by motiztab
Theo, Skins is right regarding the clutch. When I got mine this year it made a heck of a racket much more than it should even for a Ducati dry clutch. I used the link that he posted regarding plates and the differing types used. Best advice I can say is get some brake/clutch cleaner in a spray can. Take the clutch apart but keep the plates in order of removal so you can put them back in the same place, give it all, plates and basket a good clean, but becarefull of the release located in the casing. Try that first before changing out for new plates.
Posted: Thu May 05, 2005 12:37 am
by jcslocum
The 750 clutch tho dry is fully enclosed. It must really be MAKING some noise to be heard over the pipes.
Clutch noise
Posted: Thu May 05, 2005 1:58 am
by Theo
It only makes the noise when you pull the clutch in "sounds like maybe the plates are scraping together?"
I will most definately take it apart and clean via the advice given. Thanks everyone! I dont know if I mentioned it earlier but I have the 1988 blue 750 paso after market pipes and I believe 90mm high compression pistons and euro tail. I fell in love with her a few years ago when my best friend bought her. Now he has a Red 1995 900ss"You might have seen her reccently on E-bay, last week he one the bid" any how now she mine, and with all the great advice she will be running new again. The bike gets alot of looks where ever I go. Most people think its a new bike and they cant believe how ausome it sounds. Hopefully I can give some great advice too in the forum someday!
Thanks again guys
Theo
Posted: Thu May 05, 2005 11:06 am
by jcslocum
Theo,
Time to check the bearing inside the clutch cover for wear/lube. If it's not just typical ducati "clatter", it might be the bearing screaming.
