750 paso dash assembly
Posted: Fri Jun 26, 2009 2:57 am
by gitarded
Anyine have a good exploded view of the dash and nose fairing, I have a factory shop manual but not much mention of the body. I got this bike partially disassembled from a friend. Have sorted it all out except how the dash goes back together in the cowl / front nose of the bike. Any pics links advice will be greatly appreciated. I did a search but didn't find much. Thank you all in advance.
Re: 750 paso dash assembly
Posted: Fri Jun 26, 2009 7:08 am
by streetsurfer
I have the headlight fairing off of my bike at the moment. Would some photos of the support frame and dash mounted to the bike help?
Posted: Fri Jun 26, 2009 8:26 am
have you checked the parts catalogue ?
Posted: Sat Jun 27, 2009 1:40 am
by gitarded
photos would be great. the only parts catalog i found didn'y have a clear view. can you steer me in the right direction?
Posted: Sat Jun 27, 2009 8:54 am
there are 3 small silent blocks that mount the instrument panel to the headlight frame.
See. Tav.17 of the Paso750 parts catalogue which you can find in the download thread on top of the P750 forum.
Posted: Sat Jun 27, 2009 8:59 am
by persempre907
Probably, you'll find them in very bad shape...
Posted: Sat Jun 27, 2009 10:20 pm
by gitarded
Thanks for the info. I see the blocks you were talking about now. Great site and info. I downloaded it all. I have not decided yet if I am going to put it back stock or make it naked. The other thing I confirmed is that the oil coolers are held in the fairing sides by fear!
Posted: Sun Jun 28, 2009 7:16 am
by ducapaso
never seen a good looking naked from a paso frame
Posted: Sun Jun 28, 2009 8:06 pm
by persempre907
If you want a good naked bike, buy a Monster.
You can get her as you want.
As Nicola told, no naked Paso has ever looked good.
Restore your Paso
Posted: Sun Jun 28, 2009 11:05 pm
by gitarded
I don't know about that. I could make some aluminum panels to cover the bits an pieces, I hammered out an aluminum Manx style tank for a buddies 450 desmo. I might be able to come up with something to make it interesting. So am I correct about the oil coolers??just wedged in and held there by fear?
Posted: Mon Jun 29, 2009 1:31 am
by streetsurfer
I am sorry for the delay on the photos. I'll try to get some tomorrow. I'd like to move the bike into better light and give myself more room. I can try to show how the fairing is lowered down, but I won't have the side panels or tank on to match it up to. I should be able to give you a general idea of how to get started.
There are rubber caps that fit the top and bottom of the coolers. They provide a snug fit, and hold the coolers in place. Lubing them with silicone or a light grease helps with removal and replacement of the fairings.
Posted: Mon Jun 29, 2009 2:28 am
by gitarded
No problem on the pics. I think I have it figured out. One of the other members steered me to the parts catalogue download. So whenever you get the chance the pics will be appreciated.
