original front brake lever still available ??
Posted: Wed Jul 01, 2009 5:19 pm
by holla
Hi all, the front brake lever on my 907 is damaged at the end. anyone know if they're still available??
I've seen copies but none with the brembo badge in them.
Re: original front brake lever still available ??
Posted: Wed Jul 01, 2009 5:24 pm
by persempre907
They are still used by many new bikes.
So, you'd have to find them easily.
Posted: Wed Jul 01, 2009 11:27 pm
by 93IE
I just purchased a new one with a new front master cylinder from Yoyodyne. Entire assy. was about $100 with freight. Lever was identical to the one that came on the bike. They have a catalog on the web, and am sure you can buy just a lever.
Good Luck
Preston
Posted: Mon Jul 06, 2009 8:33 pm
by Desmo_Demon
holla wrote:Hi all, the front brake lever on my 907 is damaged at the end. anyone know if they're still available??
Many of the newer Ducati's with the "coffin" style master cylinders use the same levers. I know that the ST2/ST4 use the same levers up to '02. The problem is that most of those are silver and not black. If you want black ones, I think
www.bevelheaven.com sells what I believe to be original Brembo levers in black for around $25-$30 each.
