need help troubleshooting my 907ie
Posted: Thu Jul 02, 2009 11:48 pm
I bought a 907 that had been sitting. I went thru the entire thing except the inners.
Finally I got all the old varnished gas out of the fuel system.
fired right up & ran strong on the stand. when I rode it up the street, if died when I let off the throttle. after another cleaning it ran good! up & down the street GREAT!
the next morning I took it for a lil ride. 1/4 mile out 7 on the way home I stoped for a 12 pack. I started it & drove off(kickstand was down) It popped & lurched a bit. I stopped @ the road to wait for traffic,it died, I kicked up the stand & tried to start it again. it popped & vaporized gas puffed out of the intake/airbox. It also made a sound like(on a car)the flywheel or starter gear teeth had broken off. it catches for a split second then spins out with a CLUNK!
I removed the starter & tested it, good!
checked the teeth, clean. so I replaced it & the cover.
since it was open I checked the valves, all good except the hrozontal cyl exhaust has NO play @ all!
I pulled the plugs & shifted it into 6th gear, so I could turn the engine easily. now, it won't shift all the way down to 1st & it seems to be in neutral between shifts(wheel lock), the neutral light don't come on now either.
Anyone have any ideas?
I pulled the clutch cover & the spring loaded pressure plate, its rod has 2 rubber rings that are flat...???? wondering if they have anything to do with it, clanking.... ??? while accessing the starter, I noticed that the kickstand sensor wire was broken... I soldered it back on...??? cut off switch???
Wondering if when I spun the starter gear round to access the bolt holes , if I some how threw off the gearing...? or shifter?
I'm not a novice to motorcycle repair, I worked @ a Ducati dealership as a mechanic & have had several other bikes I worked on myself. With that said, I relied on the owner to diagnose symptoms I could not or direct me to the section of the repair "bible".
He retired & I can't find a dealership who will take a look @ it, saying they don't repair anything before 1998... (WHAT?)
My manual is like 150 pages with 1 paragraph of English on each page, USELESS! Is there a "Chilton" manual for the 907?
I've been working on "my baby" for a year now, buying & replacing parts as I found them. She sure purred nice, until I went on that ride, now all she says is CLUNK...whizzzzzz, clunk & won't shift.
I just want to ride her... ONCE!(well, ride her alot...)
Anyone have any ideas? Know of someone who WILL work on her here in So California? Much more of this & I will ride/push(i wish ride)
her off a cliff or use her for target practice!
@ my whits end
Regards,
Jay
socalbeekeeper@yahoo.com
@ my whits end
Regards,
Jay
