paso fuel pump over runnig carbs
Posted: Sun Jul 05, 2009 1:40 pm
by gitarded
Ok, so I have I cleaned the carbs out, replaced fuel lines and started the bike. I had oiled the cylinders down so some smoke but cleared up. The fuel pump however is pushing fuel out of the overflow vents of the 2 dellorto's. I have a return line and double checked float levels and made sure they were seating. The pump never seams to shut off. Also, the previous owner had carb jets in the fuel line leading to each carb. So maybe he had this problem and thought he was going to fix it. Any suggestions?
Re: paso fuel pump over runnig carbs
Posted: Sun Jul 05, 2009 10:12 pm
by ducapaso
yes, bypass the pump: dells don't need it!
Posted: Mon Jul 06, 2009 1:29 am
by gitarded
Really??? No pump for dellorto's? I thought the pump was there because the outlet from the tank is lower that the carbs. Here's the deal for today. Re checked float levels and tried my "test" gas tank that hangs like an IV bottle and they don't leak. Then tried it with the pump and they don't leak. I found out the jets in the fuel line were for the emission system from the canister to the carb, the previous owner used it as thefuel lines. Now I just need to adjust the carbs so it will idle properly.
And yes I am still thinking about making it naked.
Posted: Mon Jul 06, 2009 10:15 pm
by persempre907
Posted: Mon Jul 06, 2009 10:16 pm
by persempre907
Posted: Tue Jul 07, 2009 1:06 am
by gitarded
Had a Monster. No money in the budget for a new bike. So the freebee Paso fits the bill.
Posted: Tue Jul 07, 2009 11:07 am
by jcslocum
gitarded wrote:Really??? No pump for dellorto's?
Nope, no pump is needed. Just bypass it and unplug it. The Weber was higher than the fuel outlet but the Dell's are OK. Don't forget a fuel filter.
Posted: Sat Jul 11, 2009 1:47 am
by gitarded
Thanks again for the help. I also got a 4 x 8 sheet of aluminum to start cutting up to see what I can come up with as a naked aluminum tanked and faired paso. I'll probably need a new leather bag and malletbu the time i'm done.
Posted: Sat Jul 11, 2009 9:26 am
by persempre907
Posted: Sat Jul 11, 2009 10:40 pm
by Crusher
I have a similar problem was wondering if you also disconect the return line as well since the carbs wont be under preasure?
Posted: Mon Jul 13, 2009 11:49 am
by jcslocum
You can remove it if you wish. The Dell's work great with just a gravity feed.
Posted: Mon Jul 13, 2009 2:07 pm
by 21783mike
How about the Mikuni's?
Posted: Mon Jul 13, 2009 3:09 pm
if you have Mikunis keep the fuel pump and the return line also. (an extra pressure regulator is also not needed)
Posted: Mon Jul 27, 2009 8:14 am
by Finnpaso
When i had 40 mm Dellortos in my 750 Paso, i didnt use fuel pump and it function well... Ok, maybe "little too thirsty"...
